First post, by Centroid
I have tried running QFG 41/2 and I get a message that says I need DPMI. I have read through the FAQ trying to find a way to enable it and can not find it. Any ideas on how to enable it on DosBox.
Reply 2 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
uhm download cwdpmi or how is it called again.
Water flows down the stream
Reply 4 of 5, by rcblanke
Seems to work fine in CVS with cwsdpmi r5, sb16 and general midi in 320x200. Choosing an alternative resolution (640x400 or 960x600) does not work; either Allegro or dosbox itself crashes on starting the game, in that case.
Regards,
Ronald
Reply 5 of 5, by Centroid
Thanks, that worked.
