Space Quest 6 problem
First post, by MusicallyInspired
I've tried many ways to get SQ6 working properly (including the Windows version, but I want the DOS version preferably) and VDMSound, unfortunately, seems to be the only way to run it smoothly enough. Only thing is, the music is just too slow for me. It bugs me to no end (which is why I don't like using VDMSound). I've tried Speedset but whenever I try to run it with the game it crashes before it starts with this in the command prompt:
VDMSound is covered by the GNU Public License (GPL), version 2 or later, as
published by the Free Software Foundation, Inc. (http://www.fsf.org/).
Loading 'VDDLoader.dll'...
Poor man's DOS speed controller (ver. 1.0.2)
Copyright (C) 2001 Vlad ROMASCANU
SPEEDSET is now resident on IRQ 6.
Checking for Space Quest 6 CD in drive D:
DOS/4GW Professional error (2002): transfer stack overflow on interrupt 1Ch at C
7:000023D0
TSF32: prev_tsf32 48E0
SS 21F DS 0 ES 0 FS 0 GS 0
EAX 0 EBX 21F ECX 1 EDX 0
ESI 4962 EDI 49BC EBP 4982 ESP 4894
CS:IP C7:000023D0 ID 1C COD 0 FLG 2
CS= C7, USE16, byte granular, limit 38B0, base 110800, acc FB
SS= 21F, USE16, byte granular, limit 7CFF, base 40197C0, acc F3
DS= 0, USE16, byte granular, limit 0, base 40197C0, acc 0
ES= 0, USE16, byte granular, limit 0, base 40197C0, acc 0
FS= 0, USE16, byte granular, limit 0, base 40197C0, acc 0
GS= 0, USE16, byte granular, limit 0, base 40197C0, acc 0
CR0: unavailable
If I run it without speedset it works fine (save for the annoying slow music). What should I do?
Reply 1 of 2, by eL_PuSHeR
Did you try advanced options for VDMSound, i.e, Cap DOS frequency and such? Also, you could try replacing DOS4GW with DOS32A (Search forum for info)
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by Spikey
We've been there and done this before. I've tried gettign this fixed for years. The simple fact is Speedset does nothing for later SCI1/SCI32/VESA games, LSL6 CD and beyond. Works for KQ6CD, about the last one it works for. It certainly doesn't for QFG4, and SQ6 and such. I've never got a straight answer about it, so..
- Spike
