First post, by buckeye
I know it's overkill but wanting to get some DOS games running on my win98 system (see sig) and dukenukem3d
is not cooperating as starting it just gets a black screen. Upon hitting the "windows" button I can then opt out of it.
I noticed starting the install it was going to be weird, black screen at first then hit cntrl-alt-del, then the install
screen appears so it installed ok after that. Ran the setup with sound/video (800x600) which didn't show any
problems but in the end the game won't start, just get a black screen.
The quadro card only has DVI, and the monitor is a square 19" Acer LCD with 1280x1024 max. res. Could scrap the
Quadro and stick in a GF2, Diamond Viper 770 Ultra, Real 3D Starfighter but I'm stubborn so there's that. Anyone
been done this road and can offer some tips?
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 1 of 7, by Srandista
Are you open minded about source ports? If yes, you can try either JFDuke3D with OpenGL renderer or xDuke with SW renderer only.
Reply 2 of 7, by buckeye
Actually I use Eduke32 on my XP rig, works well. Believe I tried jonof's version and it was kind of slow on my win98 rig, probably need a tualatin to pull that off.
Reply 3 of 7, by DosFreak
Guess you could try testing the VESA modes in real DOS first to verify the card supports them.
Make your games work offline
Reply 4 of 7, by Srandista
eDuke32 is go to source port for XP and up, but those recommended by me should work on Win 98.
Reply 5 of 7, by oohms
Use a dvi - vga adapter and a vga cable instead.. DVI is a bit funny with older setups
DOS/w3.11/w98 | K6-III+ 400ATZ @ 550 | FIC PA2013 | 128mb SDram | Voodoo 3 3000 | Avancelogic ALS100 | Roland SC-55ST
DOS/w98/XP | Core 2 Duo E4600 | Asus P5PE-VM | 512mb DDR400 | Ti4800SE | ForteMedia FM801
Reply 6 of 7, by buckeye
I have one of those, will try it out and post the results.
Reply 7 of 7, by buckeye
Well, tried the adapter and the game started then froze at the duke nukem "emblem". I've seen time and again on this forum where others have a geforce4 ti card but have no problems running DOS games. What am I missing here?
