Reply 40 of 64, by ZellSF
wrote:Same sh*t, different game: idol janshi suchie pai III (it uses directx 8.0a).
Modded d3d8.dll does nothing. Dgvoodoo2 doesn't support this game.
The included version of DirectX has nothing to do with which API the game uses. That game uses DirectDraw, so this:
wrote:Same problem exists with some games using older Direct3D versions since Windows 8, to fix those, you can use Compatibility Administrator and enable DXPrimaryEmulation shim for the game with -DisableMaxWindowedMode parameter. See this for details, post #66. Note that Compatibility Administrator linked there is the old version, use the one bundled with Windows 10 ADK.
There's another workaround mentioned in this thread too. See if you can find it. Also, it works fine in dgVoodoo2 in windowed mode if you uncheck "Disable Alt-Enter to toggle screen state".
wrote:wrote:Why are you so sure it's a MS issue and not a driver issue or both?
MS and/or Intel should definitely fix this crap. 🙄 😜
They won't.
Edit: also should mention it works fine on my setup just so you know it's not a issue that affects everyone. I think it's either Microsoft or Intel's handling of hardware rotated displays.
