First post, by SRodney
Back in 1997, my last year of high school, my mom finally got us a "family computer" that I had in my room...
Pentium 150, 16mb EDO, 1.2Gb Fujitsu HDD, 33.6 ISA Modem, Opti931 ISA audio card, S3 Trio64V2/DX PCI video card.
I've added a Diamond Monster 3D and 32mb of ram in it before deciding (and actually being comfortable) to build my own brand new PC from scratch.
So, in 1998... I've build my first custom system !
- Diamond Micronics C200 motherboard (ALI Aladdin V)
- AMD K6-2 @ 400
- 64mb of PC100 SDRAM
- 8.4Gb Quantum Fireball
- Panasonic 32x CD-ROM
- Diamond Viper V550
- Diamond Sonic Impact S90
- took the Diamond Monster 3D and 33.6 modem from the Pentium.
The Motherboard gave me lots of problems (incompatibilities between early nVidia chips and the Aladdin chipset) so, I've opted for a new board: AOpen AX59 Pro.
In 2004, It was time to build a new system... so, at that time, this was it's specs:
- AOpen AX59 Pro (VIA MVP3, 1024 kb cache)
- AMD K6-2 @ 550
- 256mb of PC100 SDRAM
- 40Gb Seagate Barracuda
- Panasonic CD Writer (SCSI)
- Visiontek Xtasy GeForce4 MX420
- 3dfx Voodoo 2 1000
- Diamond Monster Sound MX300
- AOpen FM56/ITU-2
- Adaptec FastSCSI controller
But that's not all... I still own it... and I still retro-game on it.
Here are it's current specs:
- AOpen AX59 Pro
- AMD K6-2+ 570 @ 600
- 256mb PC100 ECC SDRAM
- 40gb Seagate Barracuda
- LG CD-RW Drive
- 3dfx Voodoo 3 3000
- Realtek 10/100 LAN card
Half-Life runs awesome on it.
EDIT: corrected on-board cache quantity.
Reply 4 of 7, by SRodney
3DMark99 Max
3547 3dmarks
8042 CPU 3dmarks
ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
System Speed Test Ver 4.78 Report file - created on 07-09-2019 00:07:26
CPU is in V86 mode: No
Processor : AMD K6(tm)-2+ 600 MHz
Frequency via TSC : 601.34 MHz
External clock : 100.22 MHz x 6.0
CPUID (TFMS) : 05D4 Codename: Sharptooth(0.18um)
Feature : 008021BFh MMX(tm):Yes, IA SSE:No, IA SSE2:No
Extended CPUID : 06D4
CPU Name String : AMD-K6(tm)-III Processor
Extended Feature : C08029BFh 3DNow!(tm):Yes, 3DNow! Extensions:Yes
L1 Cache size : 64 KB
L2 Cache size : 128 KB
Write Allocate : Enabled
CPU speed index : 668.11
Total memory size : 256 MB
Memory Bandwidth : 244.25 MB/s
AGP Video : 3Dfx VooDoo3 GUI+3D Accelerator
Support AGP rate : 1x, 2x
Desired AGP rate : 2x
AGP Operations : Enabled
AGP SBA : Supported, Status: Enabled
AGP Fast Writes : Not Supported
AGP Status Reg. : 07000223h
AGP Command Reg. : 07000302h
VESA OEM String : 3dfx Interactive, Inc.
VESA video memory : 16384 KB (64502 KB/s)
Hard drive 0 : 4865C 255H 63S 37.27 GB
ÀÄÄÄÄÄ Model (PM): ST340014A
Tested in FULL mode
Average/Max seek time : 12.47 ms / 18.87 ms
Random seek time : 11.11 ms
Track-to-track seek : 1.77 ms
Random access time : 15.40 ms
Linear verify speed : 29623 KB/s
Min/Max verify speed : 27962 KB/s / 30424 KB/s
Linear read speed : 12545 KB/s
Min/Max read speed : 12469 KB/s / 12568 KB/s
Buffered read speed : 13137 KB/s
Hard Drive speed index : 666.90
Mainboard chipset : VIA VT82C598 Apollo MVP3
BIOS vendor : Award Modular BIOS v4.60PG (08/07/02)
OS version : MS-DOS 7.10
ATA/ATAPI Device Information
IDE0ÄÂÄMasterÄ<ATA-6>Ä ST340014A
³ Cylinders: 4865, Heads: 255, Sectors: 63 (37.27 GB)
³ Serial Number : 5JX59AWA
³ Firmware Revision : 3.06
³ Maximum Transfer Mode : PIO 4, DMA 2, UDMA 5 (ATA-100)
³ Selected DMA Transfer Mode : UDMA 2
³ Cache Buffer Size : 2048 KB
³
ÀÄSlaveÄÄ<Empty>
IDE1ÄÂÄMasterÄ<Empty>
³
ÀÄSlaveÄÄ<ATAPI>Ä HL-DT-ST CD-ROM GCR-8526B
Firmware Revision : 1.01
Maximum Transfer Mode : PIO 4, DMA 2, UDMA 2 (UltraDMA/33)
Maximum Transfer Speed : 9173 KB/s (52X)
Selected Transfer Speed : 9173 KB/s (52X)
Cache Buffer Size : 96 KB
IDE2ÄÂÄMasterÄ<Empty>
³
ÀÄSlaveÄÄ<Empty>
IDE3ÄÂÄMasterÄ<Empty>
³
ÀÄSlaveÄÄ<Empty>
Cache/Memory Benchmark
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Read ³ Write ³ Move ³ Average ³
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ Cache Level 1 ³ 2104.12 MB/s³ 2287.06 MB/s³ 2290.33 MB/s³ 2227.17 MB/s³
³ Cache Level 2 ³ 1471.88 MB/s³ 1272.00 MB/s³ 1366.31 MB/s³ 1370.06 MB/s³
³ Cache Level 3 ³ 491.35 MB/s³ 216.09 MB/s³ 215.43 MB/s³ 307.62 MB/s³
³ Memory ³ 242.34 MB/s³ 115.68 MB/s³ 115.73 MB/s³ 157.91 MB/s³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
MMX(tm) Cache/Memory Benchmark
³ MMX Read ³ MMX Write ³ MMX Move ³ Average ³
³ Cache Level 1 ³ 3340.67 MB/s³ 2948.74 MB/s³ 1756.19 MB/s³ 2681.87 MB/s³
³ Cache Level 2 ³ 2040.61 MB/s³ 1437.07 MB/s³ 1475.95 MB/s³ 1651.21 MB/s³
³ Cache Level 3 ³ 501.28 MB/s³ 216.11 MB/s³ 219.70 MB/s³ 312.36 MB/s³
³ Memory ³ 242.26 MB/s³ 115.64 MB/s³ 115.54 MB/s³ 157.81 MB/s³
Memory Modules Information
SMBus/i2c Host Controller : Not Present
PCI/AGP Device Information [PCI 2.10, AGP 1.0 (2x)]
[00-00-0]
ÀÄÄÄÄÄ VEN_1106, DEV_0598, REV_04, SUBSYS_00000000
VIA Tech VT82C598MVP Apollo MVP3 System Controller
Class Code : 060000 - PCI to Host Bridge
Memory Base Range 0 : E0000000 - E7FFFFFF (128MB)
[00-01-0]
ÀÄÄÄÄÄ VEN_1106, DEV_8598, REV_00
VIA Tech VT82C598MVP/694x Apollo MVP3/Pro133x PCI to AGP Bridge
Class Code : 060400 - PCI to PCI Bridge
[00-07-0]
ÀÄÄÄÄÄ VEN_1106, DEV_0586, REV_47, SUBSYS_00001106
VIA Tech VT82C586B PCI to ISA Bridge
Class Code : 060100 - PCI to ISA Bridge
[00-07-1]
ÀÄÄÄÄÄ VEN_1106, DEV_0571, REV_06, SUBSYS_00000000
VIA Tech VT82C586/B,VT82C686A/B,VT8233/A EIDE Controller
Class Code : 01018A - IDE Controller
I/O Base Range 4 : 6400 - 640F (16)
[00-07-2]
ÀÄÄÄÄÄ VEN_1106, DEV_3038, REV_02, SUBSYS_12340925
VIA Tech VT83C586B USB 1.1 Controller
Class Code : 0C0300 - USB (UHCI)
I/O Base Range 4 : 6800 - 681F (32)
[00-07-3]
ÀÄÄÄÄÄ VEN_1106, DEV_3040, REV_10, SUBSYS_00000000
VIA Tech VT86C586B Power Management Controller
Class Code : 000000 - Unknown
[00-09-0]
ÀÄÄÄÄÄ VEN_12EB, DEV_0002, REV_FE, SUBSYS_30021092
Diamond Monster Sound II (Vortex 2 3D) Digital Audio
Class Code : 040100 - Multimedia Audio Adapter
Memory Base Range 0 : EE000000 - EE03FFFF (256KB)
I/O Base Range 1 : 6C00 - 6C07 (8)
I/O Base Range 2 : 7000 - 7007 (8)
[00-10-0]
ÀÄÄÄÄÄ VEN_10EC, DEV_8139, REV_10, SUBSYS_310411AD
Realtek RT8139 (A/B/C/813x) Fast Ethernet Adapter
Class Code : 020000 - Ethernet Adapter
I/O Base Range 0 : 0000 - 00FF (256)
[01-00-0]
ÀÄÄÄÄÄ VEN_121A, DEV_0005, REV_01, SUBSYS_003A121A
Class Code : 030000 - VGA Compatible Adapter
Memory Base Range 0 : E8000000 - E9FFFFFF (32MB)
Memory Base Range 1 : EC000000 - EDFFFFFF (32MB)
I/O Base Range 2 : E000 - E0FF (256)
End of report.
Reply 5 of 7, by j^aws
Thanks for the 3DMark99 scores. You could browse others here:
3dmark99 MegaThread
Your K6-2+ clocked at 600 MHz has a similar score to a VIA C3 Ezra-T clocked at 1200 MHz..
Reply 6 of 7, by chinny22
Nice that you held onto your first PC, not many people did and pay a small fortune to rebuild it.
You did better then me, I found it hard to upgrade when I dusted mine off a few years back as it wouldn't be "authentic"
My solution, build another similar PC with the better parts 😀
Reply 7 of 7, by SRodney
One of the first upgrades I've got on my K6-2 back in like... 99 ? was the Diamond Viper V770 Ultra (which I paired with the Monster 3D to keep Glide compatibility). The card was awesome... but now the fan doesn't work anymore so I've removed it... and need to find a replacement. I've also had a V4 4500 AGP in there... but I've damaged the card removing the heatsink... so that's why I've put a GeForce4 MX420.
I have a V5 5500 AGP which I've modded with copper heatsinks (Vantec Iceberq)... but I doubt it would perform any better than my V3 3000 on that K6-2+... I could bench it...
