First post, by Caluser2000
- l33t
What emulaters have you used on pre 2000 x86 hardware? During the '90s there was an interesting number of operating systems available for x86 systems- OS/2, Dos/Win3.x, Win9x, NT, Solaris, Linux etc. 20 years later if you havent use any in the past you can now under some kind of emulator/virtual machine on newer kit. Back then emulation existed as well. One well known *nix Dos emulator is Dosemu, it's not targeted at the gaming comunity like DosBox is but more as a way of transferring data with your Dos underlings. There were emulators for older games consols an the like as well.
Dosemu runs quite well on a P166MMX setup as does DosBox.
