First post, by ibm5155
I saw under the menu that the diagnostics disk could test alot of the hardware stuff like the Fan, Thermister ,...
But none of the files that I found worked (they were for different notebooks)
Do you guys have some idea where could I find the Toshiba diagnostics disk for the satellite 330?
Reply 1 of 9, by keenmaster486
Is this it? From the Toshiba support site, says "Windows utilities for Satellite 330".
330utl98.exe
1.26 MiB
89 downloads
World's foremost 486 enjoyer.
Reply 2 of 9, by ibm5155
I wish it was that tool, but it's the third time I'm downloading it ;(
Here, take a look about the face from this specific software:
http://i.imgur.com/whssCjn.png
I also belive that this specific tool is a generic tool, because I saw the same information and tests under different Toshiba models (including the libreto 110, [but without the fan option])
The best I did was to download the atlas software (kind of a repair software kit for companies that was going to fix Toshiba notebooks), there were some tools, but it was for 1990 - 1991 Toshiba models ;--;
Reply 3 of 9, by Cga.8086
ibm5155 wrote:
I wish it was that tool, but it's the third time I'm downloading it ;( […]
Hi
were you able to find such tool? i have been looking everywhere on google and i can´t find it.
i need the same tool that you posted images
Reply 4 of 9, by PC Hoarder Patrol
Have a look here
http://www.minuszerodegrees.net/manuals/Toshi … diagnostics.htm
The links to the 95 / 97 diagnostic program collections contain DOS apps TESTT100 & TESTT200 which have the same menu structure as the one shown in the OPs posted image.
Reply 5 of 9, by Horun
Wow great find PC Hoarder Patrol, was looking at their site earlier and missed this. Thanks !
Not sure how the Diags will work on a Satellite 110CS but will give it a whirl ;p
Reply 8 of 9, by PC Hoarder Patrol
Small follow-up on where to get these files from - came across an old post on another forum where a number of these had already been found and listed, so knocked up a quick PowerShell batch to check what was still there and tidy up the list below
ToshTnD.txt
14.27 KiB
147 downloads
Main problem is Toshiba / Dynabook choose not to expose the online directory so unless you already know the filenames or are a good guesser based on their loose naming structure, then finding any more may be a problem (is there a way to scrape data anyway in these circumstances?)
Reply 9 of 9, by martfoxy
Has anyone managed to find the original dos diagnostics for the Toshiba Satellite Pro P300 - I can't see it in the above posts. In the maintenance manual there are screen images of it - and says version 1.10. It does more than the web version available now on the Dynabook website.
Has anyone found a way of accessing the files on Dynabook via ftp or online directory (not via their web forms) ? - I could then have a look to see if the diags are on there anywhere.
