First post, by Pierre32
Just wanting to grab the correct DOS driver for the Diamond Stealth 3D 2000. The only VOGONS driver package that explictly mentions DOS is this one:
Diamond Stealth3D 2000 pro full package (DOS, win3x, winNT, winNT4, win95)
However this package is for the Pro variant. Can I use that? Or is there another one I should be using?
Reply 1 of 2, by BinaryDemon
You shouldn't really need a driver for DOS. There might be some helpful utilities like - S3VBEFIX - PC\MS-DOS TSR fix for S3 VESA 2.0 video BIOS
You might want to look into patches for 3d acceleration too.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 2 of 2, by Pierre32
Ah, thank you.
