First post, by mpe
I love using CF-IDE adaptors. What I don't like is ribbon cables floating around and the fact the adaptors needs extra power cable (unless you have a rare controller that can provide voltage on pin 20).
So I decided to mod one of these to build a solution that can be powered exclusively from the slot without any external cables.
Started with a standard CF2IDE adaptor. Unsoldered male pins, soldered female connector. Unsoldered molex connector, soldered just a plain wire and connected +5V to gameport pin:
Then I noticed that the HDD LED also conveniently provide +5V and come up with an improved variant:
yOoFe6c.jpg?1
So now I got a solid state VL-Bus storage without clunky cables which can be plugged into the slot and that's it.
Am1zfpO.jpg?1
Blog|NexGen 586|S4
Reply 1 of 5, by Warlord
i dont mind ribbon cables when they are fresh and cleanly routed. gj though.
Reply 2 of 5, by derSammler
Well, you could have just run a wire on the back that connects 5V to pin 20. 🤣
Reply 3 of 5, by mpe
The PIN 20 is connected neither on the controller nor on the adaptor.
Blog|NexGen 586|S4
Reply 4 of 5, by SirNickity
Clever! I like it. 😀 That's one of the many nice things about retro computers. They're still accessible enough to be hackable.
Reply 5 of 5, by chrisNova777
so the only thing that makes this a hack is the 1 pin power connection ? 😀
looks good tho, nice and clean! my cf adapters all face out not right angled like that one
