First post, by HunterZ
I just wanted to say congratulations to Qbix, Harkiet, and the other deleopers and testers in the DOSBox community on the release of 0.65. I was surprised to find out via a notification email from Sourceforge.
Sorry I didn't pitch in much on testing the release candidates; I've been pulled away from DOS games for a while (but I hope to come back to them soon!).
Also, news of DOSBox 0.65 is all over the Internet: http://www.google.com/search?q=%22dosbox+0.65%22
Lastly, for those who were asking: My understanding is that 0.65 is just a recent CVS build that was tested extensively by a team of volunteers and deemed worthy of being labeled an official release version. It's a good place to start if you want the most stable new version known, and is a good common reference point for reporting issues with games and/or DOSBox itself.
P.S. What happened to 0.64? Or, why was it called 0.65 instead of 0.70? Just curious 😀
Reply 1 of 5, by Lofty
451,000 results? Woah!
Reply 2 of 5, by adventur
Dosbox 0.65 is incredible! cheers all! 😁
Reply 3 of 5, by Shed
hmmm..yeah...very impressive...all games run on it 😉)
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
why it is called 0.65 😀
Tinus suggested that 0.65 was more appropiate considering the amount of changes.
Harekiet and I didn't object to that suggestion.
Water flows down the stream
Reply 5 of 5, by Gene Wirchenko
I add my congratulations as well.
I found that version 0.65 loads more slowly (taking about twice as long on my system), but seems to run quite a bit faster. With 0.63, I had some trouble with the slowness of arrow key repeating since I use DOSBox mainly to run WordStar 2000. This problem appears to be gone in 0.65 and nails one of my two quibbles.
The other is cut/copy/paste. Put me on the list of those who want to see cut/copy/paste with DOSBox. (Those who think that DOSBox is only for games should bear in mind that a good tool can be used for many things. If you still feel that one-use is the way to go, please be consistent by not assaulting me with a golf club, baseball bat, butcher knife, etc.!)
With WordStar 2000 running even better under DOSBox, I will be quite a happy coder.
Well done!
Sincerely,
Gene Wirchenko
