DOS Full-Screen Problem with Toshiba Tecra
First post, by stelth
hi i have a toshiba tecra with 12.1 screen,but when i try to play quake (320x resolution) it appears like a little square,how can i scale it? thanks
Reply 2 of 22, by stelth
DosFreak wrote:
Assuming this isn't a bot. Change the game resolution.
i tried but it's like the same
Reply 4 of 22, by stelth
DosFreak wrote:
Check your BIOS for options for the screen.
what's the key to go to the bios in toshiba series? tried F2 but didn't work
Reply 5 of 22, by realnc
Is this a DOS laptop? Or is this a question about dosbox? If it's about dosbox, you're in the wrong forum section.
Reply 6 of 22, by stelth
DOS Laptop from Toshiba Tecra Series, it has a 12.1 inches monitor, 1024x768 resolution (12.1 inches) ,when i try a dos game it appears like this:
how can i fix it?
Reply 7 of 22, by stelth
stelth wrote:
DOS Laptop from Toshiba Tecra Series, it has a 12.1 inches monitor, 1024x768 resolution (12.1 inches) ,when i try a dos game it […]
how can i fix it?
any ideas please?
Reply 8 of 22, by MAZter
check bios options first
Reply 9 of 22, by stelth
MAZter wrote:
check bios options first […]
what's the key to go to the bios?
Reply 10 of 22, by stelth
Here's my BIOS
When i try to play duke:
Reply 11 of 22, by realnc
Maybe "text mode stretch" might help.
Reply 12 of 22, by stelth
Works in the BIOS but not on Windows,still has the black edges when i play a DOS game
Reply 13 of 22, by stelth
pls some help?
Reply 15 of 22, by stelth
DosFreak wrote:
Ok i checked it but...how it runs the program? you only need to replace the other old vepex.exe and that's it? thanks anyway
Reply 16 of 22, by stelth
DosFreak wrote:
P.S How do i burn a CD for windows 95? When i tried to insert my CD-R burned with CDBurnerXP it didn't recognize it at all in Win95 but worked fine in Win 98,idk
Reply 17 of 22, by Stiletto
Moved thread.
do the Fandango!" - Queen
Stiletto
Reply 18 of 22, by stelth
UPDATE
I installed VEXP TSR and now the full screen feature works fine,but it doesn't scale all my screen,it stills has the black borders,how can i fix that if it's possibile?
Perhaps i fixed the sound problem,I enabled the sound option in the BIOS and installed the crystal audio config and now it plays MIDIs pretty good.
Reply 19 of 22, by stelth
stelth wrote:
UPDATE […]
UPDATE
help pls
