First post, by Soddy
Dear Sir or Madam,
can anyone help to suggest me how to solve "Entet full path where .FON files are located :
Error: can't register fonts"
once i shot the exe file from folder, will indicate this alert.
My purposed are need to use DOSBOX to apply DOS program in WINDOWS OS, since this all EXE
files are using in Semiconductor Testing program.
    39.57 KiB
    After type an exe file
    30.29 KiB
    Before typing exe file
Reply 1 of 3, by DosFreak
It looks like you mounted the directory incorrectly. Your program shouldn't be running in the root of c:\ but in a subfolder.
Make your games work offline
