Reply 20 of 37, by doogie
50 shades of.....yellow
The bezels on the bay devices really stood out as yellowed when installed next to each other and in this new case. I started disassembling them, and this'll actually be my first real foray into retrobrighting. Disassembly was easier than I thought, the most difficult part was actually the light pipes on the Plextor drives; whereas the buttons on the face of the drive are just pressure fit on a plastic peg, the light pipes are fit onto a similar peg, but that peg is then melted down to ensure it never goes anywhere.
Fair enough, a little finesse with the xacto knife and out they come. I'm thinking a couple of blobs of hot glue for reassembly should do the trick.
As for the Live! Drive, I'm happy I pulled this thing apart as there's a chance to really get in and clean it.
NSFW shot of the Drive:
I'm sourcing some 40 volume clear developer peroxide and will warm up the food sealer as well as the sous vide; I'm very thankful for both the 8 Bit Guy's as well as RetroManCave's videos on the topic.
