First post, by lemonlime
Hi All,
I'm working on a 486 build at the moment. It will be an AMD 486 DX2/80 that will be used mainly for DOS gaming. Right now, I've got a combination VGA and I/O VLB card based on the Trident 9400CXi chipset. It also has an OAK OTI086 chip on the card as well, which I assume may be for basic VGA purposes. The card seems to work well at 40MHz, even without changing the jumper for higher frequency operation.
This is the card here:
https://vswitchzero.files.wordpress.com/2018/02/486_3-6.jpg
It is much faster than an ISA Mach 32 I've tried in the system, but I don't think it's a great card from a VLB perspective. I am thinking of disabling the VGA portion of the card via jumpers and using it for IDE/IO and then using a separate VLB card for graphics purposes. I'm mainly interested in getting the best possible performance out of low-resolution DOS games (Doom, etc). Windows acceleration is a nice-to-have but not my primary concern. Compatibility with some pickier games like Commander Keen would be good as well, as I've had some issues with ATI cards and that title. A decent DAC for image quality would also be a plus. Any recommendations?
Many of the popular ones, including Tseng ET4000 cards are really hard to find here in Canada. I've seen a lot of CL GD5428/5429 cards around that seem to be good performers, as well as some S3 805 based cards.
Thanks!
Also known as vswitchzero. Check out my YouTube channel: https://www.youtube.com/c/vswitchzero
Reply 1 of 18, by lemonlime
Actually, looks like I may be mistaken about the Oak Technologies OTI086 chip. It isn't a VGA core like the ones used with Weitek based cards, Seems it is a "Dot Clock Generator" .. "capable of generating up to 16 video clock frequencies and 4 memory clock frequenies" .. "used to replace multiple crystal oscillators to reduce cost". I'm not sure, but I doubt that it would have any negative impact on VGA performance at all.
Reply 2 of 18, by cyclone3d
Yeah, it shouldn't have anything to do with VGA performance.
Not sure you will really notice much of a difference for DOS stuff with a higher end VLB card.
How much RAM for the vga does it have? If only 1MB, you should be able to upgrade it to 2MB by populating the RAM sockets on the card.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 18, by lemonlime
Yeah, that's my dilemma. I don't have another VLB card to really compare it with, unfortunately. The Trident TGUI9400CXi isn't supposed to be a very good VLB card, but it is way better than the ISA cards I've tried. I'm just not sure if a faster VLB card will make games like Doom noticeably smoother.
It has 1MB. Any idea from the pictures what type of chips I'd need for this or where would be a good place to source it?
Reply 4 of 18, by SirNickity
In DOS, there's really not a big difference. The Tseng ET4000 is a bit over-hyped, IMO. It was a fast series of chips for ISA, but the VLB version is just kinda middle of the road. A Cirrus card will give you great compatibility and plenty of performance. They're also easier to find.
I have an ATI Mach64, which is fast but not really much faster than some of my other cards. It has great Windows drivers and made a huge difference back when I got one for my brand new 486DX2/66. AVI files played so smooth!
Reply 5 of 18, by lemonlime
Thanks for the info about the ET4000, SirNickity. That's good to know.
I may try with the Trident card to see how it goes. I've never run it with a CPU as fast as a DX2/80 so I'm hoping the extra CPU power may help too. I found some 70ns DRAM DIP-20 ICs on eBay for a good price as well so will try to upgrade to 2MB for some higher resolution support as well.
Reply 6 of 18, by mpe
I own at least two dozens of VL-Bus card. My experience is that in DOS, unless you pick a really wrong one there is nothing to write home about. It is all about interface speed and several cards can saturate that and give you almost identical performance. In Windows there are more substantial difference between different chipsets due to different acceleration, DAC, memory types, etc.
If all you want is to experience DOS you can pick pretty much anything, incl. CL-GD542x. If you are obsessed about small performance gains and performance tuning (like most of us here), then the safe bet is tier-1 card which is one that using this chipsets:
ET4000 w32i/p, Mach64, S3 864/868/964/968, Trio 64, ARK 1000/2000. On used market these tend to be pricier than cards with other chipsets.
To give you and idea what the difference is like:
Blog|NexGen 586|S4
Reply 7 of 18, by derSammler
The Trident TGUI9400 is as fast as an S3 805, but adds GUI acceleration. It's really not a bad card at all. At least not the VLB version.
Reply 8 of 18, by The Serpent Rider
It all boils down to which CPU you use. With DX2-80 the difference between cards is negligible, but with AMD 5x86-160 it could be much more profound in some games. And not all top tier cards are on friendly terms with 40Mhz VLB bus.
Reply 9 of 18, by Unknown_K
The Diamond Viper VLB Witek 9000 isn't even used in DOS, you have a cheap Weitek VGA chip or an Oak Technology OTI087X using its RAM under an 8 bit path so DOS speed sucks.
I have one of those IDE/Serial/VGA boards from Seanix Technologies with the WD90C33 VGA chip and didn't know it was decent in DOS.
Reply 10 of 18, by mpe
Unknown_K wrote on 2019-12-31, 05:05:
The Weitek 9000 can be actually used in DOS in VESA modes if you load VESA driver or UniVBE (notice the competitive score in PCBENCH 640x480). However, VGA modes are handled by Weitek 5186 that sits on ISA bus and thus the poor results in other tests.
Blog|NexGen 586|S4
Reply 11 of 18, by The Serpent Rider
You can force Build engine games to use VESA 320x200 mode. It also will provide performance boost on normal cards.
Reply 12 of 18, by lemonlime
Thanks everyone for the information. In the end, I decided to just keep the Trident card. I found some cheap DRAM on eBay and upgraded it to 2MB successfully.
https://pbs.twimg.com/media/EOP0HIuWkAE3DNc?f … &name=4096x4096
https://pbs.twimg.com/media/EOP0HItXUAgFNKT?f … &name=4096x4096
At 80MHz and a 40MHz bus, Doom runs surprisingly well. In fact, it's noticeably smoother than at 66/33MHz. There is a jumper for >33MHz operation on the card, which I assume adds a wait state, or increases a divider or something. Thankfully it runs fine without it at 40MHz. Seems the extra bus speed increases the memory throughput of the Trident card quite a bit. As an added bonus, compatibility with some pickier games seems to be great - especially keen4/5 etc.
Just waiting on a proper heatsink for my 5 volt DX2-80. This thing runs SUPER hot. I can see why they transitioned to 3V CPUs at around this time.
Reply 13 of 18, by lemonlime
Well, I couldn't leave well enough alone 😁
I found a VLB Powergraph C33 (Western Digital WD90C33 w/1MB) for a great deal on eBay. Seems like a great card, but as others suspected earlier, I'm very CPU bottlenecked and the difference is minimal. I see only a 1 fps improvement between the two cards. I ran the following configurations and benchmarked Doom:
66mhz/33MHz bus, Trident 9400 = 24.2fps
80mhz/40MHz bus, Trident 9400 = 28.4fps
66mhz/33MHz bus, WD90C33 = 24.7fps
80mhz/40MHz bus, WD90C33 = 29.4
Do these FPS figures seem about right for a 66 or 80MHz 486?
I'm tempted to just keep using the all-in-one Trident card as it's got 2MB now and seems to behave well at bus speeds beyond 33MHz. I've been having issues keeping stable with the WD90C33 and a VLB I/O card and a 40MHz bus. It works fine with an ISA I/O card or with a VLB I/O card at 33MHz though.
Reply 14 of 18, by derSammler
Both cards can do more than your CPU allows. The fps looks fine to me.
Reply 15 of 18, by Anonymous Coward
For some reason I've never owned a Weitek card before (probably because of their reputation for poor VGA performance), but my understanding is that there are several different configurations available. I think originally the cards all used Weitek's 5286 VGA graphics core (with dedicated 1MB DRAM), but it was either slow or defective so manufacturers replaced it with the OTI chip (which was also awful). Those usually had just 256kb of dedicated DRAM to work with, and a lousy 16-bit interface. I think some cards allowed you to upgrade to 512kb. They also only used the ISA section of the card, even though the P9000 cards were all VLB.
...and, I *think* there was also a far less common configuration for the P9000 cards that paired them with Cirrus Logic 5420 chips (but these were also constrained by low memory and ISA bus).
Does anyone know what the VGA performance of the P9100 is like? These all seem to have VGA cores integrated into the main chip.
Reply 16 of 18, by mpe
Anonymous Coward wrote on 2020-02-08, 03:09:
Poor. The VGA core in P9100 is based on Weitek 5186 that was often paired with P9000. Vidspeed reports mem write speeds roughly 4-5x slower than S3 Trio64 PCI.
This was not meant to be used as a VGA card.
Blog|NexGen 586|S4
Reply 17 of 18, by Anonymous Coward
That's pretty retarded. Weitek was well aware that their VGA was slow, because every magazine pointed it out. The followup to the P9000 should have done something to address the problem. Instead all they did was integrate the mistake.
Is it possible to disable the VGA core on the P9x00 cards and use a separate VGA adapter through the feature connector?
Reply 18 of 18, by Jed118
lemonlime wrote on 2020-01-16, 15:53:
Thanks everyone for the information. In the end, I decided to just keep the Trident card. I found some cheap DRAM on eBay and up […]
That's hilarious - I just picked up the same card from Poland, and it is ALSO going into a DX2/80 MHz machine (Texas Instruments 3.3v CPU, motherboard IDs it as a Cyrix though) - I found that moving the jumper to >33 MHz results in a no-post situation (post card reader stops at 4A-4B) until the jumper is removed. This card is pretty good actually - I recently did a comparison between some ISA cards, and the 8900-D was quite good, faster than a Mach 64 in some cases.
What's for sale? my eBay!
