Worms United
First post, by Arantor
I tried to run Worms United through DosBox 0.65 on my PC. I turned my original CD into an ISO file with IsoBuster (well, it's a .BIN file but it has the same effect as an ISO file) and run the game from my harddrive, and I've had no problems playing the game itself.
Unfortunately I don't get any music with it, only the sound effects. Is this a known bug with DosBox, or just something I'm doing wrong with my ISO file? I can't play the game regularly through DosBox, mounting the CD drive won't give me sound either as the cable from the CD Audio output on my drive isn't connected to my soundcard. (It's a long story, but I haven't fixed it yet)
Any ideas?
Thanks,
Pete
Reply 1 of 2, by DosFreak
Create a .BIN with a .CUE file with Isobuster and mount the image with the "imgmount" command in DosBox.
If the game uses CD Audio tracks then this is what you must do.
Make your games work offline
Reply 2 of 2, by Arantor
Thanks, I'll give it a try.
