Tyan S1562 Dual Pentium MMX succes
Reply 20 of 36, by chinny22
Duel CPU, Awesome
Duel MMX, Awesome and rare
Getto Fix, Now has character as well 😀
Reply 22 of 36, by luckybob
Short answer; No.
Long answer; kinda.
unless you know exactly what parts on the motherboard need changed. Intel dual cpu setups require a special chip installed on the motherboard, that chip also has to be installed and properly configured via resistors on the board.
There is another thread on this forum where someone is attempting the same, but with a Pentium Pro.
Reply 24 of 36, by luckybob
I didn't think you could use MMX chips on these boards, so my whole world is turned upside down.
I know the "official" jumper settings stop at 66mhz. Going further would likely depend on undocumented settings of the individual signal gen.
Reply 25 of 36, by feipoa
What is the part number on the PLL? Spec sheet might show a frequency table.
I also didn't think p233 MMX chips would work on these boards, but after reading the thread it sounds like the reliability is uncertain.
Reply 26 of 36, by flupke11
The PLL is an ICS9159C-02 if I can read correctly from a picture I took a few months back.
I'll take it out of storage and run a few tests on it this week.
One interesting thing to check is the EDO/FP issue on the 8 slots.
Reply 27 of 36, by feipoa
Datasheet attached. Looks like 66.6 MHz is the max you can go.
Concerning EDO and FPM on my dual P233 MMX board (NEC Proserva V Plus), I actually noticed the cachechk memory read throughput decreased when using EDO compared to FPM, that is 79.2 MB/s vs. 81.9 MB/s. Not sure why this is or if it is a common result among these dual HX boards. I'd be interested to know what your benchmarks show for EDO vs. FPM. Those values above are using a P200 though. I haven't yet test the EDO again with the P233 MMX chip installed.
    ICS9159C-02C.pdf
    311.88 KiB
    61 downloads
Reply 29 of 36, by feipoa
That's quite the collection. Is that EISA/PCI one an NX chipset?
I don't really understand the difference between the S1562/3/4 boards.
Do any of your boards support a 75 MHz FSB?
Reply 30 of 36, by pentiumspeed
Tyan brings bad memory back in the day, I helped guy purchase his nice setup using dual pentium tyan board, 420MB WD and installed win98se, new memory. Corrupts the win98 and crash.
When we returned, seller is gone. 🙁
I was not sure how good Tyan is ever since and I had not seen any Tyan boards personally or owned one.
Cheers,
Great Northern aka Canada.
Reply 32 of 36, by flupke11
In order to keep things tidy, I'll update this thread with some info and an issue involving the cacheable area.
I'm configuring this system as an all purpose 90's machine (DOS to WIn2K)***. It currently has 4*32 EDO installed (Bank 0 and 1), my COAST module has one tag RAM, the second is installed as the manual demands and all jumper settings are correct to unlock the full cacheable range of the chipset, i.e. 512 MB.
I've replaced the DALLAS, which luckily was socketed. The system happily detects a 32GB CF card on the Startech adapter.
When selecting 512MB instead of 64MB cacheable range in the BIOS settings (Chipset Features screen), I get errors all around: speedsys hangs when it starts to check the cache speed, Win98 hangs at install as well as Win2K.
The manual does not deal with that option, I suppose it's a later addition. The manual also was not aware that the S1562D can run 2 P233MMX's, so that's not much of a help.
Any ideas in how to unlock the proper cacheable range?
*** I know it's useless to have a dual system when using DOS, but I need to drastically reduce the systems I hoard have, so I'd rather keep the duallies.
P.s. the difference between the S5162 and later iterations (S1563-S1564) is at least apparent in one area: no more COAST. With the fiddling I had to do to keep it properly seated, I understand they got rid of it.
Reply 33 of 36, by flupke11
Second update: CTCM7 test:
512 in BIOS, 2CPU: error at Cacheable Area L1: "A20-Error via Himem Prog stopped"
512 in BIOS, 1CPU: idem
64 in BIOS, 2CPU: no errors in CTCM7, cacheable area correctly identified as 64MB.
Reply 34 of 36, by SilverHawk
Very nice! I regret the day I got rid of my Tyan Tomcat 1564D. It was hard to come by when new and the one I received had a faulty onboard IDE controller. I threw in an IDE controller card and used it for quite awhile. I believe I still have the original manual somewhere.
Reply 35 of 36, by Sphere478
luckybob wrote on 2020-03-02, 22:37:
If the fsb jumpers are three two position jumpers your chances increase exponentially of finding undocumented settings. Loop up the data sheet for the clock gen.
On mine I found undocumented 83mhz setting that the clock gen supports that I plan on trying (different single socket board)
But on that note, I actually just ordered a Tyan S1563 Tomcat Dual Socket 7 AT Motherboard
And am pleased to see that dual mmx 233 is possible
I am hoping for more though.
I was hoping for dual tillamook but I hear they totally removed the connection to the smp pins on those chips, so unless the board has it’s own smp controller which I don’t think it does I don’t think it will work except single chip.
I also would like to run dual k6 but again not expecting this to work at all. 🙁
Though if I get ahold of a super old socket 5 or any that has it’s own smp controller, from what I read those two scenarios may become possible but of course a power leap interposer would be required on both sockets on a socket 5 or socket 7 with wrong voltage options.
Many boards, their lowest voltage settings are realized with all voltage jumpers removed but this isn’t always the case. Toms hardware did one oldie tuning or something rather was the name where they had to install a bunch of jumpers to lower the voltage.
Sphere's PCB projects.
Reply 36 of 36, by Sphere478
flupke11 wrote on 2019-09-08, 17:26:
Update, fixed the issue with the COAST module more or less by a thread: […]
CPU-0 gets 219 on Integer and 135 on Floating
CPU-1 gets 209 on Integer and 136 on Floating
System seems to behave now with the cache all bound up.
I think your memory issues may have been the way your ram was installed in slots 1,2 and 5,6
As apposed to 1,2 and 3,4
