First post, by ychh0
This is my 486 PCI board that I got from university laboratory in late 1990’s. At that time laboratory people changed their PC to new one and I got one free from them.
Thesedays I’m trying to re-new my old PC’s and just started looking around this one to set another 486 PC. Today I found that I almost forgot everything about this board and I don’t have much information about this mainboard. For example, after spending some time I found that with EDO ram I should precisely set ram type as EDO otherwise CF card cannot be read properly showing error message in spite of being recognized well and success to boot up to stage of reading it.
Anyway I‘m willing to setup a AMD 5x86 160MHz system and want to confirm some information.
- CPU :
I have two AMD 5x86 and both are upgrade modules. One is Evergreen 5x86 upgrade module with heat sync and the other is PNY qucik chip 586. I should have to set voltage at 5V to use these but I can only see jumpers for setup 3.3V , 3.45V, 3.6V and 4.0V. Are there some late 486 boards do not support 5V and maybe I cannot use these upgrade module on this mainboard? If someone has manual of this mainboard please share it to me. And also I wonder these CPU upgrade modules are also capable of OC to 160MHz.
- FSB/PCI setup :
I can see only 25, 33 and 40MHz jumpers and PCI divider is 1:1 and 1:1/2 only. If I set 40MHz FSB, PCI also operate at 40MHz with 1:1 setup and ISA will be 10MHz. Are these setup are OK in terms of hardware stability?
- Cache memory :
It seems 4 GMC6512-15 and one TK62256-15 are L2 caches. Are these ok at 40MHz or should I change them to 12ns or 10ns ones?
- Ram :
EDO or FPM? If there is EDO 50ns and FPM 60ns which is better?
- Mouse :
There is no PS/2 mouse port so it seems serial mouse should be used. But serial mouse is too old and not convenient to use. Are there any other options?
- PCI/ISA board :
There are 3 PCI and 4 ISA slots but one PCI and one ISA slot bracket is overlapped at the middle. Therefore it seems 2 PCI/4 ISA or 3 PCI /3 ISA is max. installable. Are there anyone who use all of these 7 slots and if then how?
Please see attached mainboard picture. And if someone knows detailed information about it - manufacturer, model, last BIOS to update and so on, please let me know. If possible, I want to find the manual of this mainboard.
Reply 1 of 12, by Anonymous Coward
I once had one of these boards, but it was dead and I couldn't get it working. I am pretty sure the manufacturer's name was Sunnyvale Labs, but I can't seem to find any information on it. PCchips M921 looks identical, so it was most likely a case of badge engineering.
Reply 2 of 12, by RacoonRider
1) You might want to consider 150MHz, it's usually faster.
2) If you use jumpers for FSB settings, there might be undocumented options out there. Just check the FSB block for jumper positions following the same logic, but missing in the manual. It can be risky though.
Reply 3 of 12, by PC Hoarder Patrol
Anonymous Coward wrote on 2020-03-28, 04:47:
Thinking of the SYL8884? - this thread mentions it (with links) and the ST1A REV B
TD-4IP-UMC-AIO PCI Socket 3 Motherboard
Reply 4 of 12, by ychh0
PC Hoarder Patrol wrote on 2020-03-28, 05:14:
It seems my board is very close to the one or may be the same. I happened to remember that in the late 1990’s SOYO 486 PCI board was very popular in Korea and I heard that mine is also made by SOYO. It could be.
I nearly figure out how to set jumpers except for CPU type part. I don’t understand how to to set up 1-2, 3-4 and so on. It’s like a puzzle to me.
Reply 5 of 12, by ychh0
RacoonRider wrote on 2020-03-28, 05:07:
How will be the performance between 150MHz and 160MHz?
150MHz : FSB 50MHz and 3x, PCI should be 1/2 resulting 25MHz (there is only 1: and 1:1/2 setup)
160MHx : FSB 40MHz and 4x, PCI 40MHz OC or 20MHz (1/2 of FSB)
I plan to use PCI video card/VOODOO2 and PCI UW scsi board. PCI speed difference may affect
performance.
Reply 6 of 12, by RacoonRider
I have a similar system configurable via front panel switches to multipliers 3 or 4 and bus speeds 25MHz, 33MHz, 40MHz, 50MHz. I can get a fast benchmark of any combination if you like. PCI:FSB ratio is 1. Are you interested in any particular software?
Full spec:
Am5x86-133ADZ
AOpen AP43 (512Kb L2 cache)
64MB RAM
Matrox Mystique 2Mb
etc.
Concerning Voodoo 2 on a 486: it's not a good idea. Even the fastest 486 will not be enough for any 3dfx card. I used to have a 233MHz PentiumMMX with a Voodoo Graphics card and even at maximum clock I could squeeze out of the system, it still sometimes felt underpowered for Glide gaming. Then I got a 450MHz Pentium II and 2xVoodoo2 and GLide stuff started to really shine.
Reply 7 of 12, by ychh0
RacoonRider wrote on 2020-03-28, 07:32:
I have a similar system configurable via front panel switches to multipliers 3 or 4 and bus speeds 25MHz, 33MHz, 40MHz, 50MHz. I […]
Full spec:
Am5x86-133ADZ
64MB RAM
Matrox Mystique 2Mb
etc.
There is no particular S/W in mind. As written above I wonder how will be the performance of three system - AMD 5x86 150MHz/PCI 25MHz, AMD 5x86 160MHz/PCI 20MHz and AMD 5x86 160MHz/PCI 40MHz.
Reply 8 of 12, by ychh0
It seems I can get max. 512kB L2 cache according to information found in PC Hoarder Patrol shared link.
It says L2 cache was upgraded to 512kB using 4 UMC UN611014BU-15. Current cache memory installed on my board is 4 GMC6512-15 and 1 TK62256-15. Should I change TK62256 and to which?
Reply 9 of 12, by RacoonRider
No, TK62256 is TAG RAM, you do not need to change that. For 512K cache with your board, you'd have to use 4 1024k cache chips. Rare, expensive, and does not change pretty much anything in terms of performance for a 486.
It's only needed to make RAM over 32 MB (WB) or 64 MB (WT) cacheable and let's be honest, 32MB is already overkill for a 486. That's true for my chipset (SIS 496/497), it might be different for UMC.
Reply 10 of 12, by RacoonRider
Okay, I checked the sources and it turns out that I was wrong and PCI divider on SIS496/497 is automatically set at 1 at 25/33MHz FSB and 1/2 at 40/50MHz FSB.
Here are the benchmark results for Phil's benchmark suite from January, 2014:
CPU______PCI_____3Dbench__PCplayer_Quake__Doom(lower is better)
133MHz___33MHz___63.9_____19.6_____12.3___1759
160MHz___20MHz___77.1_____23.7_____14.8___1468
150MHz___25MHz___84.2_____24.6_____14.8___1366
Reply 11 of 12, by ychh0
RacoonRider wrote on 2020-03-28, 09:09:
Okay, I checked the sources and it turns out that I was wrong and PCI divider on SIS496/497 is automatically set at 1 at 25/33MH […]
CPU PCI 3Dbench PCplayer Quake Doom(lower is better)
133MHz 33MHz 63.9 19.6 12.3 1759
160MHz 20MHz 77.1 23.7 14.8 1468
150MHz 25MHz 84.2 24.6 14.8 1366
Wow. Thanks!
Interesting. It is certain that FSB speed affects performance a lot. When I finish building system, let me compare two system, FSB 40MHz/CPU 160MHz/PCI 40MHz and FSB 50MHz/CPU 150MHz/PCI 25MHz
Reply 12 of 12, by Anonymous Coward
Indeed it was an SYL8884. The manual is available for it, but strangely it doesn't list the manufactuer's name. I was pretty sure the BIOS on my board had a holographic sticker that said "Sunnyvale Labs" on it, which seems to line up with the SYL in the model number. So even though these look basically identical to M921 they actually have different jumper settings? That's pretty weird. I wonder which one that the OP actually has.
*edit*, ah, I saw ST1A on the poster's board. So are these yet another variant? SYL8884 should have a PS/2 mouse header. I don't see it on this board.
