First post, by sam767
ok so i dust off two version of Mortal kombat 3 one with Win9x installing the second without !
installed two Mortal kombat 3 individuallly (Windows 9x and Windows 98) none of them work !
the game shows fine untill i press (Start Game) withing less a millisecond flicks of unknown picture then screen turns Totally BLACK the audio Tracks still playing in Background tho
i tried OpenGL , Direct3D and Software . with and w/out Voodoo 3Dfx Drivers , tried many display Devices (Tseng, Trident extra )
after all these solution i've check MK3 properties by Clicking RMB there's few things in Memory tab i mess with but Absolutely Nothing
i knew i could it play it on DOSBox but it's too fast even adjusting CPU Cycles won't be accurate enough
Reply 1 of 3, by Jorpho
sam767 wrote on 2020-03-30, 22:09:
That seems unlikely.
In any case, if this game runs in DOS, what happens if you restart in MS-DOS mode from Windows 9x in PCem, and then try to run the game?
Reply 2 of 3, by sam767
yeah I got it to work ! restarting windows in ms-dos after I installed CDROM driver
I guess I need to install sound drivers too ! and then edit autoexec.bat and config.sys ? any guide for this ?
Reply 3 of 3, by Jorpho
It should work pretty much exactly like any DOS installation, and I'm sure there are lots of guides for that.
/MOD EDIT - Reword and link removed due to links
Google "set up sound card drivers in pcem"
