First post, by Jackhead
i grow up with DOS Games (build 1982) and like to get the old games back with midi.
So i managed to get me a MT32 (old) for the beginning.
Unit is still on the postway and i have some questions.
My question now:
I like to use my headphones (Byerdynamic T1) with the output on the MT32.
So my headphone has 600 ohm and i wonder if i need a amp behind the MT32?
Most videos i watched people use old active speaker systems.
regards
Chris
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 5, by imi
they are line level outputs, so unless you want to listen to really silent music or potentially risk a lot of clipping I would suggest so, yeah :p
Reply 2 of 5, by Jackhead
I was thinking so too, ok thanks 😀
second question:
For setting up on my old PC i can use the midi port on my soundcard ok. But if i have the chance to get a MPU-401, should i go with the external or interal version?
What are the differents beside the one is isa and the other external. Do both exactly the same job ?
thanks 😀
Reply 3 of 5, by darry
All original Roland MPU-401 interfaces for the PC require an internal ISA card and external breakout box .
Later Roland MPU-401 models and MPU-401 clone cards may consist of in ISA card only .
There are no external only MPU-401 interfaces, they all require an internal card .
See https://en.m.wikipedia.org/wiki/MPU-401
EDIT : some corrections
Reply 4 of 5, by keropi
you have 2 options to drive a MT-32 when the "roland intelligent mode" is needed
1. software option: SOFTMPU that will work with existing soundcard mpu
2. hardware options:
a. find an old roland or compatible interface
b. get a hardmpu or pcmidi card
Reply 5 of 5, by Jackhead
got it thanks!
regards
Chris
