First post, by ultra_code
Updates
  • (2/18/2020) I have finally gotten the best GPU I can buy for this system - a Nvidia GeFroce 6800 Ultra. I got the card and installed it in December, redoing all of the benchmarks and such, and playing Deus EX: GOTY on it, but have only gotten around to updating this post now. New benchmarking data can be found below.
Intro
It has been nearly 1 and a half years since I first put together my second retro gaming machine (my S478 Pentium 4 PC), and like with my Pentium 3 system, this system was asking for an upgrade. The case was sub-optimal, and with the modding I had done to it near the I/O shield which removed the paint where I had crimped the metal, it had actually started to rust. The CPU, while decent, well, wasn't the "best" of the Pentium 4s in terms of clock-speed (nick-picking at this point). Also, the one-hard drive solution for both 98SE and XP, while great, opened the opportunity that in the event one of the installs went bad, and I wanted to redo that given install, it would put the other install at risk of having to get wiped.
So, I decided to rebuild the system from the ground-up: new motherboard with the same 865PE chipset as the previous Asus P4P800, but more importantly a new socket - socket 775 (Asus P5P800), a new CPU to go along with it, more RAM for XP, separate SSDs for 98SE and XP (really pulling a Druaga1 here; this actually was almost a no-go if it weren't for a PCI SATA card I happened to have had on-hand in storage that supported both OSes), a new aftermarket GPU-cooler that was both period-correct and more importantly didn't block the SATA ports on the motherboard (it performs just as good as the modern Arctic Accelero Twin Turbo II that I had on my 6800GT, but without being as big), and, but of course, a brand-new higher-end case to replace the crap-tastic budget case that was the Deepcool Tesseract I had. Eventually, I even upgraded the GPU in this new rig to a 6800 Ultra.
The result: a truly epic Pentium 4 RGM.
Details
Check out my full Imgur album (Pentium 4 S775 Windows 98SE/XP Retro Gaming Machine) showing off this build. If I add to this machine any more (perhaps a 6800 Ultra in the future?), I will update this album.
For a complete list of nearly every part in this build and the cost of each part, check out my "Financial Accounting for Pentium 4 S775 Windows 98SE/XP Retro Gaming Machine" Google Spreadsheet.
A list of specs:
  • Intel Pentium 4 HT 672 SL8Q9 CPU (Cooled by a Cooler Master Hyper 212 Red LED CPU Cooler)
  • Asus P5P800 Socket 775 Motherboard with 865PE Chipset
  • 2x G.Skill F1-3200PHU2-2GBNS 400Mhz DDR 2GB Kit (2x1GB) RAM (4GB total; RAM limited to 512MB under 98SE using HiMemX)
  • BFG Nvidia GeForce 6800 Ultra 256MB AGP Graphics Card
  • 2x Team Group L5 3D T253TD120G3C101 2.5" SATAIII SSD
  • Toshiba Samsung Writemaster SH-S202J IDE Optical Drive
  • GOTEK 3.5" USB Floppy Drive Emulator (SFR1M44-U100K)
  • Creative Sound Blaster Audigy 2 ZS (SB0350) PCI Sound Card
  • Adaptec SATAConnect ASH-1205SA PCI SATA Card
  • Corsair Carbide 200R CC-9011023-WW ATX Mid-Tower PC Case
  • Corsair CX450 80+ Plus Bronze 450W Power Supply
The Build
Unlike with my upgrade of my Pentium 3 system, the upgrade process was... difficult. Getting all of the parts together and putting them into the new case was easy, but that was the beginning of my problems. Probably the first problem I faced was trying to transfer over the previous 98SE and XP installs on the old incarnation's hard drive onto each of their own SSDs - that proved fruitless. I would have to pull everything I would want off of them, reinstall Windows onto each SSD, and then put the data back where it was in the old install. Not hard, but tedious. Then was trying to have two separate SATA drives in the system. You see, 98SE cannot boot if your SATA/IDE configuration in the BIOS is set to "Enhanced Mode," because it cannot handle the non-traditional assignment of 2 IDE master/slave pairs + 2 single-drive IDE devices by the BIOS; instead, 98SE requires "Compatibility Mode" to function, which forces the BIOS to either one SATA + IDE port, or only both of the IDE ports on the motherboard. This prevented me from plugging in both SSDs into the motherboard's two SATA ports, let alone use the IDE optical drive at the same time. Thankfully, the addition of the Adapter PCI SATA card I had in storage solved this problem. I would still have to use "Compatibility Mode", but because the PCI SATA card takes care of 98SE's SSD, everything works out, and there are no issues to speak of.
Finally, the last "problem" (more of a concern) I encountered had to do with how 98SE and XP created their partitions. Both OSes existed before SATA SSDs and SSDs in general were really a thing for the consumer (that goes without saying), so when they create their partitions, they don't "align" the partitions properly, in addition to who knows what else (the subject of disk geometry is confusing to me). So, in the hopes of both extending the life of the SSDs and perhaps getting better performance out of them, I decided to format them under Linux Mint using gparted (and then in 98SE's case using fdisk to mark the partition as "active). Sure enough, gparted knows what SSDs are, and both disks are properly "aligned." How much this helps, I have no clue, but it probably doesn't hurt.
To further extend the life of the SSD XP is using, I then proceeded to tweak XP's settings - disabling prefetch, increasing disk cache size (if it wasn't already enabled), disabling disk defragmentation and the background moving frequently-accessed files to the start of the disk (https://www.prime-expert.com/articles/a06/per … based-netbooks/), and basically disable indexing of files on the drive (I didn't out-right disabling indexing in "My Computer" on the off-chance it might help; I just made it so XP indexes like zero files upon boot-up, reducing the time it takes for me to actually begin using the OS) (https://www.techrepublic.com/blog/windows-and … -the-right-way/).
As for the gaming experience on this new machine, well... it's probably barely a noticeable upgrade over the old incarnation when it comes to in-game performance. I'm sure the extra 400MHz and the newer Prescott 2M architecture helps, but how much is beyond me. Likewise, the bump up to a 6800 Ultra should help a little too, but again, the performance increase would be relatively small at best. However, synthetic benchmarks are sure to show. 😁
At this point, the only two things I can think of to make this RGM even faster is a Pentium 4 3.73 Extreme Edition CPU (SL7Z4) OCed to maybe 4.0GHz if possible, and a Nvidia GeForce 6800 Ultra Extreme Edition, both of which I'd imagine the chances of me finding either for a "reasonable" price, if at all, to be worse than winning the Powerball lottery. Therefore, unless I strike it lucky, this build is essentially complete. 😁
Benchmarks
What's a post about a retro PC without some benchmarks, eh? Along with the 3DMark results for the 6800GT for both incarnations of this machine as well as those for the 6800 Ultra, all with the percent differences listed, I'll include some disk benchmark results, like I always do. However, unlike previously, in addition to including results for the 3DMark benchmarks with the settings "maxed-out," I'll also include "default"-settings run results, so that these numbers are more comparable to other benchmark results people have gathered (if you want to see want "maxed-out" settings look like, check the Imgur album linked above).
Here are the 6800GT results, both for this incarnation and the previous one:
Under Windows 98SE:
  • 3DMark99:
    • "Maxed" (1280x1024, highest-possible settings) - 23227 (original result - 20076; 15.7% improvement)
    • "Default" - 24210
  • 3DMark2000:
    • "Maxed" (1280x1024, highest-possible settings) - 22687 (original result - 19072; 19% improvement)
    • "Default" - 23308
Under Windows XP Professional SP3:
  • 3DMark2001SE:
    • "Maxed" (1280x1024, highest-possible settings) - 15673 (original result - 14025; 11.75% improvement)
    • "Default" - 20997
  • 3DMark2003:
    • "Maxed" (1280x1024, highest-possible settings) - 5050 (original result - 5169; 2% loss)
    • "Default" - 11268
  • 3DMark2005:
    • "Maxed" (1280x1024, highest-possible settings) - 3295 (original result - 3232; 1.95% improvement)
    • "Default" - 5111
Next, here are the 6800 Ultra results, with comparisons to the previous, recent 6800GT results:
Under Windows 98SE:
  • 3DMark99:
    • "Maxed" (1280x1024, highest-possible settings) - 23569 (2% improvement)
    • "Default" - 24206
  • 3DMark2000:
    • "Maxed" (1280x1024, highest-possible settings) - 22948 (1% improvement)
    • "Default" - 23147 (1% loss)
  • 3DMark2001SE:
    • "Maxed" (1280x1024, highest-possible settings) - 16310 (4% improvement)
    • "Default" - 22267 (6% improvement)
  • 3DMark2003:
    • "Maxed" (1280x1024, highest-possible settings) - 5844 (16% improvement)
    • "Default" - 12695 (13% improvement)
  • 3DMark2005:
    • "Maxed" (1280x1024, highest-possible settings) - 3737 (13% improvement)
    • "Default" - 5781 (13% improvement)
Finally, here are the disk benchmarks ran under Windows XP Professional SP3:
  • Roadkil's Disk Speed Version 2.0:
    • "C Drive" (XP SDD, connected to motherboard's SATA port)
    • "E Drive" (98SE SSD, connected to Adaptec PCI SATA card)
  • CrystalDiskMark 6.0.0:
Regarding the newer 6800GT 3DMark results, it does seem that the newer, faster Pentium 4 has indeed demonstrated an improvement in performance, mainly in the older benchmarks that are so blown-out of the water by the hardware that any rather significant bump-up in hardware makes an impact. Comparing the .3dp files of the "maxed" runs from my original P4 machine to this one, there is indeed a noticeable increase in FPS, with a massive FPS-difference between the systems in "Game 1 Car Chase," respectable improvements in "Game 2 Dragothic" & "3 Lobby," and no change in "Game 4 Nature." It is only in 3DMark03 and 05 does the system see no real change in benchmark results, probably because the benchmarks are GPU-bottlenecked at this point.
As for the 6800 Ultra 3DMark results, though, one could argue that the step up to the higher-tier card was not really worth the doubling in cost, at least for 9X gaming. There was virtually no difference between the cards in 3DMark99 & 2000. However, under XP, the difference was more pronounced, especially in the later, more demanding 3DMark03 & 05 benchmarks. I'm sure I could extrapolate this trend to a 6800 Ultra Extreme Edition and say yet again that under 9X, there'd be no real uplift, while the opposite would be true under XP. I'm guessing those 9X benchmarks, and perhaps by extension 9x games, are already so thoroughly destroyed by the 6800GT, that the higher-tier cards can't do much more to them. 😁
Onto the disk benchmark results. Since both SSDs are identical, the determining factor for these results is where they are plugged in (ether straight into the motherboard or into the Adaptec card). The XP SSD is clearly maxing out the SATA I port, which have a theoretical maximum of 150MB/s. The 98SE SSD, on the other hand, makes apparent that the Adaptec card is not capable of meeting SATA I speeds, most likely due to PCI limitations (please correct me if I'm wrong). Regardless, both SSDs far outpace the hard drive that was in the old incarnation:
Yeah, that's slow alright. 🤣
Some Tidbits
If you want to see the complete results of all of the graphics benchmark runs I ran (which are saved to the ".3dp" files which can be viewed in each of the benchmarks' respective "Result Browsers"), you can find them in the public Google Drive folder of mine named "P4_S775_RGM_Graphics_Benchmarks" (for the 6800 Ultra results) or "Old P4_S775_RGM_Graphics_Benchmarks (6800GT)" (for the 6800GT results). In either folder, you can find the associated ".3dp" and ".3dr" files for each benchmark, as well as a file named "GBQRDT.txt", which lists the results for all of the graphics benchmark runs for the given config of the system as listed above.
If you want an offline version of the 3DMark2000 Result Browser, you can find a copy of the installation executable here in my Google Drive, straight from Futuremark's servers (find out more here 😀).
If you want to go to where I store anything I have linked from my Google Drive here click here. That link will take you to the "root" directory I created to store all of my "public" files and folders for this post of mine.
Builds
Reply 1 of 14, by chinny22
Nice tidy rig, similar to mine, even have the same cd drive, although I'm still using the Asus P4P 800-E socket 478 board.
To get around the SATA limitation I had what I thought was a moment of genius 1/2 way though the build, Use the on board RAID controller for WinXP, even just 1 disk in a "JABOD" config works fine
P4P800 End of Win98 Support Build
Wouldn't be surprised if my software raid takes a performance hit vs your real hardware card though.
Reply 2 of 14, by ultra_code
chinny22 wrote:
Nice tidy rig, similar to mine, even have the same cd drive, although I'm still using the Asus P4P 800-E socket 478 board. To ge […]
Not a bad rig - love the Corsair RAM. Some suggestions, though. One, there's no need to disable hyperthreading for 98 (or XP for that matter). 98 runs just fine with HT enabled, and can even run on Core2 CPUs on an Asrock 775i65G R3. I mean, I know some software of the day performed slightly worse with HT enabled, but probably nothing significant.
Also, while the rloew patch surely works, using HiMemX works just as well. Just download it off of SourceForge, throw, say, himemx.exe into C:\WINDOWS and add the following to config.sys before you finish rebooting to complete the 98SE install:
DEVICE=C:\WINDOWS\HIMEMX.EXE /MAX=524288
where "MAX" is the amount of RAM in megabytes you want 98 to "see." You don't have to worry about anything else after that.
Builds
Reply 3 of 14, by D3FEKT
Nice build mate, case looks much better than a Deepcool Tesseract, my P3 is currently sitting in one and I hate it 😜
Reply 4 of 14, by chinny22
the_ultra_code wrote:
Not a bad rig - love the Corsair RAM. Some suggestions, though. One, there's no need to disable hyperthreading for 98 (or XP for […]
Yeh think I found out that HT was just ignored in 98 after a while, but I could not get the system stable with the himemx trick after installing the sound or graphics drivers.
The ram is main reason this build still exists, its a bit redundant if I'm honest. Early Win9x games are happy on my P3 1Ghz and later ones that do benefit from the faster specs work fine in XP anyway. but the flashy ram is just so cool I cant bring myself to part it out.
Reply 5 of 14, by ultra_code
chinny22 wrote:
... but I could not get the system stable with the himemx trick after installing the sound or graphics drivers.
That's a bit strange. Never had an issue with HiMemX yet. I feel like something else is at fault. Just a hunch.
Builds
Reply 6 of 14, by fsmith2003
Do you mind sharing your process for getting himemx to work and the settings you used? I have an almost identical setup (Same motherboard, 6800 ultra, P4 CPU.) but I am not sure what I need to do to get the memory situation figured out? I have 3gb of RAM installed but want it to only see 512mb of it in Win 98 SE and then all of it on the XP HDD.
Reply 8 of 14, by ultra_code
fsmith2003 wrote on 2020-04-17, 21:02:
Sure.
I kinda already mentioned how to do it here:
the_ultra_code wrote on 2019-10-01, 19:09:
Also, while the rloew patch surely works, using HiMemX works just as well. Just download it off of SourceForge, throw, say, hime […]
Now here's a bit more in-depth guide.
When you go to install 98SE, the first part of the installer asks you information and begins copying files over to the hard drive. After that's done, it asks you to reboot to finish installing. After the installer reboots the machine, have bootable media with DOS and the himemx.exe executable on it (floppy disk, CD, USB, what have you; I use my Win98 bootdisk on a specially-formated USB stick for the Gotek floppy emulator). After finishing booting from said media, copy himemx.exe to wherever you want it on the C drive (can't remember where I heard this from, but a recommended place to put the executable is in the C:\Windows directory, and add the following to the config.sys file using the edit DOS-based text-editor:
Save the file, restart the machine, and continue with the 98SE installation. The installer looks at the config.sys file like a fully-installed Windows normally would, and runs whatever commands are there. Adding himemx mid-install is necessary when installing 98SE with more than around 1.5GB of RAM (?) because 98SE has an artificial RAM limit of around 1.5-2GB of RAM (hence the rloew patch to remove that limit, or himemx to work within that limit), and any more will give you an Insufficient memory to initialize Windows error or something like that IIRC. I believe this RAM limitation isn't an issue during the first part of the install because you are using DOS to begin the setup, and DOS's memory management isn't bothered at seeing 4GB of RAM (if it can actually properly see it).
At that point, you're all set up!
Now, another little important bit of information if you do plan to use himemx under 98SE with more than 1.5GB of RAM is how to successfully enter Safe Mode. If you try to enter Safe Mode on boot-up, you'll get the following error:
In order to circumnavigate this, at the Startup Menu, select "Command Prompt Only". This will load the himemx driver for use in safe mode:
Then all you will need to do to enter Windows in Safe Mode is type the following:
win /D:M
vetz wrote on 2020-04-17, 22:58:
Really nice build!
Any specific reason why you went with the 6800 Ultra and not X850XT PE when you did the upgrade?
The main reason is this: I don't know my AMD/ATI GPUs. Nvidia's GPUs are more compatible with older 9x games (like early 9x-era I believe) because of their support of palettized textures and table fog. Now, according to the VOGONS wiki, the 6000 series dropped support for the former, and the 7000 dropped support for both, as well as official 9x support (although I know you can get 7000 series cards to "work" under 9x). ATI never supported either officially, although I believe you could mod some of their drivers for some of their earliest cards to enable the features. For the games I'll play on this system, I guess support for either of those features isn't important, but it never hurts to have it just in case.
Now, the other reason why I just prefer Nvidia in general, from the FX series to my 1080, is that I like Nvidia's drivers better. AMD has nothing on the Nvidia control panel, and I've used Nvidia's drivers so much that I know them very well, and am most comfortable with them. Guess you can say I'm getting stubborn. 😁
Essentially, the thought of using an AMD GPU in this rig didn't cross my mind at all.
Builds
Reply 9 of 14, by bloodem
Did you have any trouble with the GeForce 6800 card on Windows 98?
I have a Gigabyte GeForce 6800 that is basically unusable with Windows 98. The only driver version that "works" is the last one, 81.98, but even that one is only compatible with a few benchmarks and maybe 3 - 4 games.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 10 of 14, by ultra_code
bloodem wrote on 2020-04-19, 06:38:
No issues, no. I use the penultimate driver - 81.85 - because I heard that 81.98 causes shutdown and other issues with 6000 series cards. I believe I've used 81.98 with 6000 series and had no issues, though. YMMV.
Make sure your GPU shows up in the [Strings] section in the Nvaml.inf file found in the C:\Nvidia\Win9XME\XX.XX\ directory.
Builds
Reply 11 of 14, by bloodem
The GPU does show up in nvaml.inf, in forceware drivers as early as 61.76. However most of the 6x.xx and 7xx.xx drivers will result in a BSOD right after installation. 77.72 is the first one that does not result in a BSOD, however it's still unusable.
And no, my card doesn't have a PCIExpress/AGP bridge (those tend to have issues with Windows 98).
Reply 12 of 14, by pentiumspeed
I had a HP 8300 motherboard built into this case 1 and half year ago and sold it to a co-worker.
Just one thing is top fan grilles has a disadvantage, I don't fancy small bits of stuff falling through that, especially metal.
Cheers,
Great Northern aka Canada.
Reply 13 of 14, by ultra_code
bloodem wrote on 2020-04-19, 17:33:
I mean, if you install 98SE using the ISOs from REMOVED, update to IE6.1 and WMP9 (I do that because I believe they update other parts of Windows as well, and since I can't pull updates for the OS, this is better than nothing), and update to DX9 before installing the latest or close to it GPU driver, and it still gives you issues, either your GPU is faulty, or something else in your PC is, and it shouldn't have anything to do with software. Make sure everything is on the GPU as it should be (no missing caps, SMDs, etc.).
If you need further help, though, PM me or ask the rest of the forum. I don't want this thread to turn into a tech-help thread. 😜
pentiumspeed wrote on 2020-04-19, 18:18:
Corsair Carbide 200R […]
Cheers,
It's okay. The worst thing that'll ever fall through the top is dust, but I keep my PCs relatively clean throughout the year, so no concern there.
Builds
Reply 14 of 14, by bloodem
I probably should have mentioned this, but the GPU works fine in Windows XP (since it didn't work in Win 98, I settled for XP and it's been running smoothly for a few months now). The issue with the GeForce 6xxx series and Windows 98 is very complex (you can also see it here, in Phil's video ) Seems that many things must come together in order for it to work:
1. the card: seems that only a few lucky cards work with it (and it's still unclear why)
2. the motherboard / the chipset might also play a role (maybe some cards will work on some chipsets, but will behave erratically on others)
3. other devices can also cause issues, maybe?
Anyway, you're right, let's leave it at that and stay on topic 😀 Thanks!
