First post, by austinham
- Member
I'm looking for any info on early SSD. any date before 2006. I know about CF to IDE card and the i-drive and disk on module. But what about more convenchle 2.5", 3.5" and 5.25 drives? were the ever made?
Interesting, but early disks are frequently non reliable - at least MLCs, which were the first affordable SSDs.
The MODCOMP Classic computers I scrapped at work a few months back all had primitive solid state drives by DATARAM (2MB fully populated). This was mid-1970's technology.. see here: http://www.storagesearch.com/dataram-bulkcore.pdf
These are often cited as the roots of modern SSD's. We used them from the early 80's up until 2013 and they rarely had failures. Usually it was only a single memory chip failing on a single board inside that could easily be swapped in minutes.
