First post, by buckeye
Patched with 1.3/1.31/1.32/1.33, do any of these break the option to enable cheats?
Tried the -devmode add on for the command line on the executable but no dice.
Yes I did modify/replace the "lua" file per the usual instructions.
Reply 1 of 2, by candle_86
It shouldn't at all
Reply 2 of 2, by buckeye
Candle_86, you're right. I didn't realize the devmode.lua file I downloaded was in text format. Once I saved it in "lua" format all was fine.
