First post, by zig
Hello
does anybody know if it is possible to run Settlers 2 on a LCD screen ?
When I launch it I get a display problem coming from screen refresh rate (which doesn't make sense on a LCD screen) 😒
Does any solution exists ?
thx
zig
Reply 1 of 13, by eL_PuSHeR
Do your LCD have an adjustment button?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 13, by zig
I'm on a laptop... (no screen buttons at all)
Reply 3 of 13, by franpa
run it with dosbox 0.65 and substitute dos4gw.exe with dos32a.exe.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 4 of 13, by zig
where do I find dos32a.exe ? it's not in the Settlers directory...
Reply 5 of 13, by zig
ok sorry I found it, I tried tu use it externally and internally, but the problem stays the same... any idea ?
(thanks for your answers anyway)
Reply 6 of 13, by franpa
backup dos4gw.exe (found in your settlers2 directory) and rename dos32a.exe to dos4gw.exe then place it in your settlers2 directory. (then run the game with dosbox 0.65)
my website
Reply 7 of 13, by zig
Is it necessary to run it with dosbox ? I did it with the microsoft dos emulator (in windows xp), and it didn't work.
When I try to use dosbox on Linux (Debian), I get another problem, about image loading...
I'll may try with dosbox on windows...
Reply 8 of 13, by franpa
yes... windows and dosbox.
my website
Reply 9 of 13, by zig
ok it works !
thanks !
but it runs a bit slow... I tried to increase cycles up to 90% of my CPU and to set core+full in dosbox.conf, but it is still difficult to play 😒
Do you know if it's possible to make the game more playable ?
Reply 10 of 13, by eL_PuSHeR
Try dynamic core, not full, if you are looking for speed.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 11 of 13, by zig
Still not playable...
Reply 12 of 13, by bugs_bugger
The smotthness of Settlers 2 depends strongly on map size and visible area. Very small maps run smoothly, but if you want to play FanPaign, you will have live with 0.5 fps.
Reply 13 of 13, by zig
well I gave up 😒
I play Widelands now, a free Settlers 2 clone. But I met a bug in the first campaign map... maybe I can play only in freemaps...
