CT4520 master race...
First post, by kitten.may.cry
Hye fwends!
Is it reasonable to solder a faster RAM chip?
I had cards with 60 and 70ns so far...been looking to uh, upgrade it! (for some kind of improvement, if any)
Should I do it?
Edit: this is not a troll thread, please comment, if you had any experience doing the same thing with your cards!
Reply 1 of 5, by Tiido
Faster RAM isn't gonna do anything at all there. What you can do is solder a 2MB RAM chip there instead of the 512KB one. There's couple 0 ohm resistors to move to allow it to work.
Reply 2 of 5, by kitten.may.cry
Tiido wrote on 2020-05-26, 21:54:
Okay. That'll do the trick.
Reply 3 of 5, by appiah4
I actually should try this.. Do you have a tutorial for what resistors to move?
Also, is there a functional difference between a 0R resistor and a simple bodge wire?
Reply 4 of 5, by Tiido
You move R18 to R17 and R19 to R16 to get 2MB support. There's no difference between 0 ohm resistor and a solder bridge or bodge wire, except current andling capability where the resistor will not reach wire or bridge ever 🤣.
Reply 5 of 5, by Thermalwrong
There's some pictures of what to change on a CT4520 / CT4500 to make it 2MB here 😀
