First post, by RainaCharity
Hello All,
I just downloaded Life and Death (from Underdog) and everything seems to be working fine. Except for a "tiny" problem...Everything I successfully do is a failure, because for the life of me I can't figure out how to get my beeper out to look at the numbers I need to punch into the phone to return someone's call. I've pressed every key, yep I downloaded the manual but that part is missing. I don't know if anyone else has encountered this problem. I told you it was a dumb question 😜 I would like to thank you all in advance for any help you can provide...I've been searching forever for this answer. Thank you I do appreciate it.
