Nexgen VLB questions
First post, by mt777
I have a few questions which couldn't find clear infos.
1) P90 runs with FSB 42MHz. Is possible to run stable with higher cpus (for example with P100?) Which VLB cards can handle ~50MHz ?
2) PF100 - I read that PCI version supports PF cpus. Maybe does exist some kind of hack to run with on VL version too?
Reply 1 of 3, by mpe
mt777 wrote on 2020-06-09, 21:29:
Yes. The Nx586 P100 runs at 93 MHz and the board does support it.
That produces VL-Bus at 46.5 MHz which is passable, but many VGA cards will need to add a waitstate reducing performance somewhat.
However, it is less problematic than VL-Bus on 486 DX-50 for example. This is because NexGen VL-Bus cards are not directly connected to CPU local bus, like on 486, but the signalling on VESA slots is facilitated by the chipset.
I don't know about any such hack.
Blog|NexGen 586|S4
Reply 2 of 3, by mt777
so only possible upgrades (from P90) are finding P100 and cache to 1MB?
Reply 3 of 3, by mpe
Not sure if you can upgrade the cache. It is soldered on the mb and there are solder pads for bigger chips so in theory, yes, but I thought the L2 cache on NexGen is 4-way associative rather than direct-mapped so upgrade past 256kB shouldn't be necessary...
Blog|NexGen 586|S4
