First post, by taxidriver
Is it just me or does it move extra slow, regardless of the cpu cycles and frames?
Reply 2 of 5, by taxidriver
I'll shut up now.
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
Works fine here with dosbox 0.65, especially with the dynamic core
if you're on linux/windows or so. Try to set the resolution of the game
to 320x200 (plain vga, should be the fastest).
Reply 4 of 5, by franpa
yes... there is no real point in setting a high res in a game when using dosbox unless there is an advantage in it... like duke 3d will look the same pretty much... but in settlers 2 you can see more at once (zoomed out more).
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 5 of 5, by ChaosFish
taxidriver wrote:
I'll shut up now.
Nah, I actually think that FAQ is obsolete. I just couldn't help but posting it 😜
