DRO versions
First post, by JessicaJones
Hi
What is the difference between DRO v1 and DRO v2?
Can you choose which version to capture in DOSBox (or is DRO v2 ONLY used now in latest DOSBox)?
Jessica
MS-DOS music addict - DOSBox/AdPlug enthusiast
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
You can't choose which version is used. Only by using a different (older) version of DOSBox
Water flows down the stream
Reply 2 of 3, by JessicaJones
Starting with what version of DOSBox was DRO v2 introduced?
Reply 3 of 3, by keenmaster486
World's foremost 486 enjoyer.
