First post, by 386SX
I was thinking which were the latest fastest 30-pin FPM simm built compatible with 386 mainboards and equally the fastest 28-pin cache modules?
In my 386 UMC481/482 board, I've 60ns rams and 15ns cache but I was thinking if faster ones would make some difference and/or just make the system unstable.
Also does the actual access time depends on the chipset so a faster cache/ram would not run at its theorical specification?
Thanks
