Problem with Munt+Dosbox
First post, by Mark_81
Hi guy
I've a problem with Dosbox and Munt
I use A DOSBox version 0.74-3 and a version of MUNT MT-32
In my Options file I set:
mpu401=intelligent
mididevice=default
midiconfig=1
sbtype=sbpro2
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=opl3
oplemu=fast
oplrate=49716
The problem I have is that when i try to type on DOSBOX line command MIXER/LISTMIDI, I' ve only one Option and ONLY "0 Wavetable Synth" and not "1 Roland MT-32" ?
In fact, When I open MUNT, I dont have the device.
Why?what's wrong?
Reply 1 of 5, by CrossBow777
you are seeing wavetable snyth because that is the default that Windows loads up and that is the only one that is appearing for DosBox to be able to use and access. You will likely need to find some additional software that will allow you to remap the midi device in windows to the MUNT emulator. On my windows PC I have two Midi options that I can choose from. One is the Wavetable Synth that is built in, and the other is my UM-ONE MK2. Sometimes after windows updates I have to use CoolMidi software to get the UM-One back in the list so DosBox will show it in the Midi list options.
So that is my guess is that the Munt emulator isn't being recognized by windows as a midi device and something else will be needed to get it added in there.
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 2 of 5, by sergm
@Mark_81
Note, if you have updated Windows recently, there is a known problem with the mt32emu MIDI driver being constantly disabled by Windows 10 2004. An update of the driver can be found at SF.
Reply 3 of 5, by Mark_81
Thanks Guys
I Have solved re-installing MUNT again..It was a driver that missed
Reply 4 of 5, by Mark_81
It's Better to set Munt on 16 bit or 32?on the properties..
Reply 5 of 5, by sergm
Hmm, isn't the tooltip appearing when you mouse-over it clear enough? 😀
If not, there is a rule of thumb: use integer 16-bit samples unless you need extremely high-quality and clean audio output.
