stalk3r wrote on 2020-08-10, 11:44:
Interesting... do you remember if yours booted with 32K cache before the fix, or only with no cache at all.
stalk3r wrote on 2020-08-10, 12:07:
I have replaced the TAG chip, but it didn't help. But then I replaced all SRAM chips and it boots and detects 128K. Too bad the the new chips are 20ns ones instead of 15. At least it works.
For me, it didn't work with 32KB cache setting either. Though, it was likely because my tag chip was bad, so it didn't matter what jumper settings I had, it wouldn't have worked anyways.
Yours happened to have bad cache chips instead, glad you were able to figure it out in the end.
I'm using my board with a RT3105, definitely not the fastest ISA card out there, but I chose it for the low profile form factor. It has to fit into this case.
