First post, by wackoreese
- Newbie
I recently tried to install windows 95 on a HOT-555A motherboard with a pentium mmx cpu. Installation goes fine without any issues, aside from it refuses to make a boot disk. When I go to try and start it after install it goes from the windows 95 splash for several seconds and just immediately reboots. Safe mode works fine, but obviously it never officially finishes setup so there's many missing drivers. Enabling bootlog is useless as the last line is alwyas LoadSuccess=C:\WINDOWS\SETVER.EXE. In safe mode everything loads without issue and I even installed the drivers for my imagine vga card to see if that was a potential issue. Instead it still gets stuck in the same bootloop. What could be causing this issue?
