Windows 98 - Controller not recognized ?
First post, by Sebiohazard
Good morning all !
I installed Windows 98 SE with DOSBox-X.
When I connect my controller, it is not recognized by Windows 98 ? Is there an option to enable in DOSBox-X or a line to write to the config file ?
Greetings !
Reply 5 of 16, by 1541
Did you try
JOYSTICK […]
JOYSTICK
Joystick needs to be set manually
Windows wants to use address 200-207, but it needs to be 201-201.
Go to Device Manager->Joystick
Switch from "Basic Configuration 1" to "Basic Configuration 0" in "Resources" in device properties for joystick.
From
Windows 9x DOSBox Guide (Not officially supported)
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
Reply 8 of 16, by Sebiohazard
Hello !
I added this line in the DOSBox-X config file:
[joystick]
joysticktype=auto
When launching DOSBox-X I launch the Mapper editor with the keys F11 + m the joystick is detected & works well but with Windows 98 it is not detected ? Why & how to proceed ?
Greetings !
Reply 9 of 16, by Sebiohazard
Hello !
I also tried with this line:
[joystick]
joysticktype=4axis
Unfortunately it is always the same problem in Windows 98, the joystick is not recognized:
I also tried changing the address as mentioned in the tutorial:
JOYSTICK […]
JOYSTICK
Unfortunately I cannot change it, Windows refuses:
How to do ?
Greetings !
Reply 13 of 16, by Wengier
You can check if the joystick works in DOS using the test programs in the attachment (previously uploaded by rfnagel).
There are 3 test programs included in it, namely JOYCHECK.EXE, JOYTEST.EXE and TMSCOPE.EXE.
If it works, then it means something is wrong with the configuration of your Windows 98 guest system.
Reply 14 of 16, by Sebiohazard
Hello thank you for your help !
I started Windows 98 under DOS & ran the diagnostic tools for the joystick. It is recognized & the keys work correctly.
But under Windows 98 always the same problem I don't know why...
What is strange is that with PCem I have the same concerns !
Greetings !
Reply 15 of 16, by Sebiohazard
Good evening everyone !
I tried a Windows 95 install to see if my joystick is recognized but I have the same problem as with Windows 98... here is the conf file I used:
[sdl]
autolock=true
usescancodes=true
[dosbox]
title=Windows 95
memsize=64
vmemsize=8
vesa modelist width limit=0
vesa modelist height limit=0
[dos]
ver=7.1
keyboardlayout=sf
[cpu]
cputype=pentium_mmx
core=normal
cycles=30000
[sblaster]
sbtype=sb16vibra
irq=5
[joystick]
joysticktype=auto
[ne2000]
# If you want networking in Windows, set ne2000=true.
# This also requires that you set realnic= to a suitable value for your PC
ne2000=false
nicirq=10
realnic=list
[fdc, primary]
int13fakev86io=true
[ide, primary]
int13fakeio=true
int13fakev86io=true
[ide, secondary]
int13fakeio=true
int13fakev86io=true
cd-rom insertion delay=4000
[render]
aspect=true
scaler=normal3x
[autoexec]
imgmount 0 boot.ima -t floppy
imgmount 2 win95.vhd -t hdd -size 512,63,64,520
Did I forget something ?
Greetings !
Reply 16 of 16, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Please use either the DOSBox-x thread or its github issues page (not sure about that, though).
These forums are for DOSBox only and not for the forks.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
