First post, by Kahenraz
I was given this old "computer" by someone but I don't know how to connect it to power.
Any advice on this?
I'm guessing that these types of backplane computers were used in industrial applications. It's pretty interesting though.
It also comes with a lovely Dallas clock chip. Yaay...
Reply 1 of 8, by Kahenraz
More photos.
Reply 2 of 8, by adalbert
There are screw terminals marked by the arrow. You need to attach wires with proper voltage to them. You could use AT, ATX or custom power supply.
Simplest, but destructive (for power supply) way: use old ATX (or AT) power supply you don't care about and strip the wires. Match colors of wires. Insert them into screw terminals and clamp down with the screws. Don't use orange wires (don't mistake them with red or yellow). If there are multiple wires of same color, you can join them together.
"Proper" way: buy ATX to AT adapter cable and remove AT connectors, insert wires into terminal block. Congratulations, you converted that computer to ATX. You can also buy miniature 12V pico ATX power supply if you want to use something smaller.
Ideally you should check the voltages before turning everything on.
Reply 3 of 8, by Warlord
you wire AT power supply to the Block on the back where it indicate 12v 5v -5v etc
Reply 4 of 8, by maxtherabbit
You should be grateful it has a dallas instead of some heinous barrel battery that leaked all over everything and destroyed it
Reply 5 of 8, by pentiumspeed
Get crimp on open end eyelets and install them by crimping to the wires. Bare wires is good for testing.
Cheers,
Great Northern aka Canada.
Reply 6 of 8, by Thermalwrong
Hey that's an Advantech PCA-6134 😀 I've got the later version of that from about '96. Get ready to desolder that Dallas to replace it or mod it with a battery, but that's great and reliable little board. Afaik you can power the board itself with a floppy connector from a PSU where you've got it always-on, but with mine it doesn't then power the ISA bus, so the video card didn't work.
Best to power the ISA backplane using those terminals. You don't need all of them to work, it should be okay with just 12v, 5v, gnd & -12v.
Reply 7 of 8, by Errius
What were these things used for? Controlling machinery?
Is this too much voodoo?
Reply 8 of 8, by imi
well anything that needed computer control somewhere, including machinery yes.
