Voodoo 5 5500 problem after flashing Bios
Reply 20 of 37, by mmmark84
I hope so 😀 would be a cheapish option for a fix
Reply 21 of 37, by mmmark84
Could these work? having a hard time finding them at suppliers like farnell and ebay.
Reply 22 of 37, by sdz
If they're legit ICs (not fakes or broken pulls) they should work. If shipping takes a long time and you're impatient, you could at least temporarily use an EEPROM from a donor card. Some TNT2 cards have this exact EEPROM, like https://www.ebay.com/itm/InsideTNC-Dream-nVid … XoAAOSwsxFeSaOc . Probably many other cards of the same vintage have it as well.
Forgot to mention, AT49BV512 should also work.
Reply 23 of 37, by mmmark84
I went over my stash and found the following cards:
I guess the only one that is usable is the 3COM one?
Reply 24 of 37, by mmmark84
on second thought, I might as wel order and wait for new ones from china. dunno if I can recover such an IC with the tools I have, while still being usable.
We got some rework stuff at my office with heatgun, but why even risk it 😀
Reply 25 of 37, by havli
Well, to be honest I am not an expert on external flash programmers. I have one of the chinese clones of TL866 II - that one would definitely work. The simple and cheap ones, I have no idea.
You can flash the new (empty chip) on the V5 itself, sure. I did the same on the defective Banshee (at the time I didn't have the TL866). There is a catch however. The 3dfx flash application only supports few selected chips. I have a list that I found somewhere. Maybe it is complete, maybe not... anyway:
Atmel: 29010, 49F010, 49BV512, 29LV512
SST: 29LE512, 29EE010, 39SF010, 39VF512
AMD: 29010
So It is best to get one of these if you intend to flash it on the card.
Reply 26 of 37, by mmmark84
ty for the suggestions! I ordered a bunch of these last weekend.
I figured I would order the exact same type as the one on the card now.
Reply 27 of 37, by mmmark84
I recapped the entire card tonight and tried to flash it again. Same result. Guess nothing left to do but wait for EEPROM chips 😀
Reply 28 of 37, by kolderman
😢 I cried.
Reply 29 of 37, by Doornkaat
I'm going to say this was to be expected but recapping a ~20 year old card can't hurt so best case after the EEPROM swap it'll be like new again! 😀
BTW: I do believe that if you have a motherboard with a EEPROM socket of the same footprint (your CUSL2-C may even have one) you can use that with uniflash to hot flash the EEPROM like a motherboard BIOS. Just saying. 😉
Reply 30 of 37, by mmmark84
Haha nice tip! but im gonna wait. its whats best in the long run I hope.
Reply 31 of 37, by ultra_code
@mmmark84, IDK if you flashed BIOS version 1.18 or 1.18.b03, but assuming you flashed the later, modded BIOS, it might be that the card is running at an incorrect clock speed for both the GPU and memory (as with 3dfx cards, the clocks speeds for each are linked). I've noticed that the settings for the built-in clock-adjustment utility in that later modded BIOS can get corrupted, but a simple reset of them can fix any graphical issues you are having as a result.
If you can access the firmware's menu by hitting F1 with a PS/2 keyboard (USB doesn't initialize until you hit the POST screen on my PIII-S motherboard, so PS/2 is your best bet), make sure your settings are set as such:
Otherwise, if you can't get into the menu, or would like to do it a bit more quickly, just hit F2 when you get to the VBIOS screen, and it'll reset the clocks to default.
If you actually flashed the official 1.18 BIOS, then not sure if I can help.
Builds
Reply 32 of 37, by mmmark84
Thnx for the tip! I tried several bios versions, the original (1.06), the 1.06 from supplied site, the 1.18 and 1.18 modified versions. all several times. I started with the official 1.18 however.
Everytime I made a dump of the firmware of the card, something in the data is at wrong spots and a few bytes are not what they need to be.
When the EEPROM chips arive, I will continue this venture and will sure to set the speeds according to your screenshot 😀
Reply 34 of 37, by mmmark84
So I replaced the EEPROM and flashed the card:
Same result....RIP I guess
Reply 35 of 37, by Doornkaat
Damn.
Reply 36 of 37, by RichB93
Time to replace the RAM on the card.
Reply 37 of 37, by Hanamichi
I might of missed it but did you try putting pressure on ram chips and the the cores while on? It helped me with a Ti4600. Might help, just remember to touch the case first to avoid static build up.
Seeing as it's two chips in hardware based SLI and half your screen is bad in stripes.. Would that indicate one chip has an issue while the other is good? I forget the rendering pattern for 3DFX SLI and I am a Voodoo 5 noob so might be a stupid idea.
