Here are the contents of autoexec and config.sys
AUTOEXEC
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E
SET CTCM=C:\CTCM
C:\SB16\DIAGNOSE /S
C:\SB16\MIXERSET /P /Q
C:\CTCM\CTCU /S
@ECHO OFF
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:DOS
GoTo %config%
:EMC
:XMC
:CMC
LH C:\DOS\MSCDEX.EXE /D:OPTICAL
:ME
:XM
:CM
LH C:\DRIVERS\MOUSE.COM
:E
: X (i put a space here, otherwise it triggers an emoji)
:C
CONFIG.SYS
[COMMON]
DOS=HIGH,UMB
FILES=40
BUFFERS=40
LASTDRIVE=H
[menu]
menuitem=EMC, Expanded memory + Mouse + CD-ROM
menuitem=XMC, Extended memory + Mouse + CD-ROM
menuitem=CMC, Conventional memory only + Mouser + CD-ROM
meniltem=EM, Expanded memory + Mouse
menuitem=XM, Extended memory + Mouse
menuitem=CM, Conventional memory only + Mouse
menuitem=e, Expanded memory
menuitem=X, Extended memory
menuitem=C, Conventional memory only
menudefault=EMC,10
[EMC]
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\CTCM\CTCM.EXE
DEVICE=C:\DOS\EMM386.EXE RAM
DEVICEHIGH=C:\DRIVERS\VIDECCD.SYS /D:OPTICAL
[XMC]
[CMC]
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
[EM]
[XM]
[CM]
[E]
[X]
[C]
Pentium I 133mhz
32MB RAM
AWE64
S3 64v+ / Voodoo 1
DOS 6.22
