First post, by foil_fresh
See the image attached - do the numbers printed on the cpacitor indicate certain values? Or is this just for the manufacturer?
This is a cap ive accidentally bent over while taking off the heatsink last night. It is one of two identical caps that sit between the ram chips. I dont really want to power this up without knowing it's in good condition so it needs to be replaced.
Thanks.
Reply 1 of 2, by Hoping
330uf 6 volts, polimer capacitor I think, but not sure it can be electrolitic. Can be replaced with a low esr electrolitic.
Reply 2 of 2, by foil_fresh
Hoping wrote on 2020-10-14, 13:35:
Thanks a million!
