CUE sheet troubles :/
First post, by Akuma
I'm trying to mount an ISO/CUE/MP3/OGG but I can't seem to get it working .
I read this: https://www.dosbox.com/wiki/Cuesheet
Literally copied this into a file:
FILE "image.iso" BINARY
TRACK 01 MODE1/2048
INDEX 01 00:00:00
FILE "track02.ogg" MP3
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 00:00:00
Than ran:
imgmount d image.cue -t iso
And got:
What am I doing wrong ? 😕
Reply 1 of 29, by jmarsh
Are you using a build that is linked with SDL_Sound?
Reply 2 of 29, by Akuma
jmarsh wrote on 2020-10-19, 13:57:
Yup, running the latest SVN (compiled yesterday) on Linux
libSDL_sound-1.0.so.1 => /lib/x86_64-linux-gnu/libSDL_sound-1.0.so.1
Reply 3 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
is the file case correct for all the files ?
Water flows down the stream
Reply 4 of 29, by Akuma
Qbix wrote on 2020-10-19, 14:13:
Yup, all lowercase.
EDIT: Almost forgot, it works when I only have the ISO in the CUE file.
EDIT2: Might be the SDL_SOUND,
purgedthe SDL packages, reinstalled them, compiling latest SVN now
(this is probably my fault, it usually is 😁)
Reply 5 of 29, by jmarsh
You need the SDL_Sound dev package for linking (and make sure it is for SDL 1.x, not 2.x) as well as the runtime library. Check the output of ./configure to make sure it gets found.
Reply 6 of 29, by Akuma
jmarsh wrote on 2020-10-19, 15:15:
Indeed, the libsdl1.2-dev was missing. I feel stupid 🙁
Reply 7 of 29, by Akuma
Well the CUE sheets are being loaded 😁
Pllaying the audiotracks only seem to work with OGG.
MP3 and FLAC stay silent ?
Reply 8 of 29, by Akuma
Does one EDIT a copy of the original CUE sheet ?
or build a new one from scratch ?
What is considered best practice ?
Reply 9 of 29, by dr_st
Akuma wrote on 2020-10-20, 19:33:
Obviously to use a tool to build it properly.
Because this:
2 TRACK 01 MODE1/2048
3 INDEX 01 00:00:00
4 FILE "track02.ogg" MP3
5 TRACK 02 AUDIO
6 PREGAP 00:02:00
7 INDEX 01 00:00:00
Is definitely incorrect. You are basically saying that both tracks start at the same time (00:00:00)
Reply 10 of 29, by Akuma
dr_st wrote on 2020-10-21, 07:20:
Obviously to use a tool to build it properly. […]
Because this:
3 INDEX 01 00:00:00
5 TRACK 02 AUDIO
6 PREGAP 00:02:00
7 INDEX 01 00:00:00
Appreciate your time, but I think you're missing something 😁
Reply 11 of 29, by jmarsh
Because this:
3 INDEX 01 00:00:00
5 TRACK 02 AUDIO
6 PREGAP 00:02:00
7 INDEX 01 00:00:00
It is valid. INDEX parameters aren't absolute timecodes, they are offsets (usually referring to the current FILE) expressed as minutes:seconds:frames. "INDEX 01 00:00:00" means use the current file beginning from the start.
Reply 12 of 29, by Akuma
I'm having trouble understanding how to convert the following CUE:
FILE "myfile.bin" BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 33:40:15
TRACK 03 AUDIO
INDEX 00 37:54:70
INDEX 01 37:55:03
to:
FILE "myfile01.iso" BINARY
TRACK 01 MODE1/2048
INDEX 01 00:00:00
FILE "myfile02.ogg" OGG
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 00:00:00
FILE "myfile03.ogg" OGG
TRACK 03 AUDIO
INDEX 00 37:54:70 <-- How do I process these ?
INDEX 01 37:55:03 <-- 00:00:00 and 00:00:$(75-70+3) ?
Reply 13 of 29, by Akuma
Ha! I found something here: http://www.totalsonic.net/cuesheetsyntax.htm
INDEX 0 Specifies the starting time of the track “pregap”
Based on that information, I think this should be it: (but wtf do I know 🤣)
TRACK 03 AUDIO
PREGAP 00:02:00
INDEX 01 00:00:00
Does anyone know more ?
Reply 14 of 29, by jmarsh
Depends if the ripping software started dumping the track from index 0 or index 1.
If it started ripping at index 0 the pregap is included in the .ogg file, so you'd want this:
INDEX 00 00:00:00
INDEX 01 00:00:08 ; 75 frames in one second so 37:55:03 - 37:54:70 = 00:00:08 (length of pregap/index 0 -> index 1)
If it started ripping at index 1 you need to use PREGAP instead (which means "insert silence"):
PREGAP 00:00:08
INDEX 01 00:00:00
Some rippers append the pregap to the end of the previous track, which would require something like this:
FILE "myfile02.ogg" MP3
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 00:00:00
TRACK 03 AUDIO
INDEX 00 04:14:55 ; 37:54:70 - 33:40:15 (length of track 2 audio)
FILE "myfile03.ogg" MP3
INDEX 01 00:00:00
(Note that all compressed audio should use "MP3" filetype regardless of their actual format."
Reply 15 of 29, by Akuma
Yikes!, that makes scripting it a lot tougher.
Regarding the MP3 filetype, I'd take it to be best practice but not mandatory ( it seems to work with OGG/FLAC)
Reply 16 of 29, by jmarsh
It's one of several reasons why using individual files for each track is a bad idea, better off just sticking with a mixed-mode .iso.
Reply 17 of 29, by dr_st
jmarsh wrote on 2020-10-21, 07:39:
I see. You are correct, of course. The index refers to each file separately and not to the overall position on the emulated disk. I looked at the wrong example on the wiki, the one which used a single binary CD image. 😊
Reply 18 of 29, by Akuma
jmarsh wrote on 2020-10-21, 09:16:
How would that work with OGG/FLAC/MP3 ?
Reply 19 of 29, by jmarsh
It wouldn't. Compressed audio brings other problems like slow seeking, loss of quality, incorrect tracks lengths...
