First post, by Andrew0Red
I've searched and searched, finding no good solutions, so I'll post this one, even if it isn't perfect:
What I did: In Nvidia control panel:
1) Change resolution -> userdefined -> create one of 1280x600 (i.e. a 2.1333 ratio)
2) Adjust desk size and placement -> Full screen (as opposed to conserve-aspect-ratio or no-stretch)
In dosbox.conf:
1) Fullresolution = 1280x600
Scaler = normalx3
And - voila! - I now have 320x200 pixels, taking up a 4:3 portion of the screen!
Technical notes: Nvidia card, and it already had resolutions of 1280x??? and ???x600, so I knew both should work.
Hope this helps someone out there!
- Andrew Red
Reply 1 of 6, by jmarsh
Have you tried output=opengl with aspect=true instead?
Reply 2 of 6, by Andrew0Red
That just doubles every 4th (5th?) line, creating some ... interesting artifacts. My method gets the proper, same-size (rectangular) pixels.
But your method sounds much simpler and safer.
Reply 3 of 6, by jmarsh
opengl output does not double lines, it uses bilinear resampling.
Reply 4 of 6, by Andrew0Red
Something like:
Fullres=orig
output=opengl
aspect=true
scaler=normal2x
Gave me 16:9, not 4:3. Am I missing something?
Reply 5 of 6, by jmarsh
Don't use fullresolution=original, set it to desktop or whatever the native resolution of your screen is (or tell the nvidia drivers to preserve the aspect ratio, not scale-to-fit).
Reply 6 of 6, by Andrew0Red
Ah, that seems to do the trick.
Man, dosbox is complicated....
