First post, by appiah4
I've been trying to save BMPs in GIMP that will be compatible with Windows 9x as wallpapers and I can't seem to find what color depth and mode I need to use.
Any help please?
Reply 2 of 15, by appiah4
leileilol wrote on 2020-12-04, 09:29:
Just stick with 24-bit and don't bother with RLE (run-length encoding).
I think I've tried this and it did not work. I even tried at 16-bit and it still failed.
Windows 98 sees the BMP but when I choose it in Desktop Properties it doesn't show up. I can however open it in Paint. Re-Saving in Paint doesn't work. Interestingly opening it in IrfanView and re-saving works.. 😒
Here are the BMP Save As options in GIMP:
19.12 KiB
Maybe I should try the "Do not write color space information" option?
Reply 3 of 15, by khyypio
That´s weird. I´ve made wallpapers with GIMP and they work. Although, I exported them as *.jpg, you might want to try that. Also, test different resolutions and set it as wallpaper straight from your picture.
Reply 4 of 15, by Jorpho
appiah4 wrote on 2020-12-04, 11:00:
Seems to me the obvious step is to do a binary compare before and after saving, and see what changes. I think I use FrHed for that.
Reply 5 of 15, by Tiido
in worst case save the BMP over original in Irfanview, it always produces correct format.
Reply 6 of 15, by appiah4
Tiido wrote on 2020-12-12, 08:49:
This is what I always do but it is an annoyance. How GIMP can not produce a Win9x compatible BMP eludes me still..
Reply 8 of 15, by Grzyb
Is it really necessary to use BMP format in Windows 98 ?
With that "Active Desktop" (mis)feature, I would expect it to also support common WWW formats, like GIF and JPEG.
Edit: but then there would still be some compatibility problems - can't expect 90s software to support modern JPEG variants...
Reply 9 of 15, by Jorpho
appiah4 wrote on 2020-12-12, 09:53:
Did you try the binary compare already? I imagine it's a matter of one or two bytes in the file header or something.
Reply 11 of 15, by K1n9_Duk3
Grzyb wrote on 2020-12-12, 12:19:
Active Desktop would probably be overkill if all you want is to have a nice wallpaper (I don't know, I never used it myself). Simply converting the image you want into a BMP file that Windows can handle should be less of a hassle, assuming you don't want to change the wallpaper every five minutes. Even Windows XP didn't have native support for JPEG wallpapers. Sure, it would allow you to select a JPEG, but it would silently convert it into a bitmap file and then use that bitmap file instead of the JPEG. Run regedit and check "HKEY_CURENT_USER\Control Panel\Desktop" if you want to know which file Windows is actually using as your wallpaper. The "Wallpaper" entry is what you're looking for.
Reply 12 of 15, by Grzyb
K1n9_Duk3 wrote on 2020-12-15, 00:16:
I thought it would be less of a hassle to let Windows do the conversion, instead of using some modern software where writing 9x-compatible files isn't straightforward.
I just did some experiments with 98SE, and:
- it does support GIF, JPEG, PNG
- when setting such a wallpaper for the first time, it displays that such formats are only supported with Active Desktop, and asks whether to enable Active Desktop
Now I'm lost - I always thought that Active Desktop is enabled by default.
But if not, then what's the reason Windows 98 is so much slower than 95 ?
Reply 13 of 15, by Jorpho
Grzyb wrote on 2020-12-15, 04:10:
If you're comparing Windows 98 to the original release of Windows 95, then Windows 98 has IE4 integrated into the shell regardless of whether Active Desktop is enabled.
Reply 14 of 15, by Grzyb
Jorpho wrote on 2020-12-15, 05:17:
OK, looks like I misinterpreted the term "Active Desktop" - I thought it was mostly about that integration of MSIE into the shell.
Reply 15 of 15, by Jorpho
Grzyb wrote on 2020-12-15, 06:53:
Removing the IE4 shell integration requires 98lite from https://www.litepc.com/98lite.html , which in turn requires files from a Windows 95 installation (depending on how thorough you want to be). But this is getting off-topic.
