First post, by BEEN_Nath_58
Midtown Madness had a problem with CD Audio, where it would not resume after the game has been paused. This was fixed by using _inmm.dll. The music now resumes but it resumes from the start of the song. Is there any particular setting I should change that would allow the song to be resumed from where it was stopped? Or is this functionality unavailable in this app? Is there any other alternative for this app which will allow music to be resumed properly?
Reply 1 of 3, by ZellSF
DxWnd is the best CDDA wrapper now I think, you should try that.
Also check out OpenMM1 / Open1560 (developer recommends Open1560, but if you want the classic D3D render you need to go with OpenMM1).
Reply 3 of 3, by BEEN_Nath_58
ZellSF wrote on 2020-12-17, 12:13:
Actually I can't get DxWnd to cooperate with dgVoodoo. I'm sure it did previously. But thankfully gho has a standalone version of DxWnd's CD audio wrapper: https://sourceforge.net/projects/cdaudio-proxy/
I was looking for a manual and got it in the original wrapper. Now it works all fine for me. Thanks 😀
