First post, by lmttn
I'm in the process of putting together a sorta Frankensteinish PC out of parts I've ordered (namely a Pentium III 800 and an ASUS P2B-F motherboard) and ones I already have (case, Voodoo3 2000, SBPCI, 192MB RAM, optical drives, etc) but I just realized that my only spare PSU is the wrong form factor for my case, so I will need to order a power supply as well. Seeing as it is an ATX motherboard, will modern ATX power supplies still be compatible, provided I get the converters needed for molex and IDE connections? Is there anything in particular that I should be wary of?
