First post, by Allanar
Hi guys,please
Which you would recommend motherboard under this processor, until 1999.
Coppermine Pentium III 600MHz or 650MHz, Socket 1,FSB 100MHz
SDRAM 128 MB,PC 100
Voodoo 3 3000 AGP
Thanks 😀
Reply 1 of 14, by leonardo
Allanar wrote on 2021-01-05, 23:39:
Hi guys,please Which you would recommend motherboard under this processor, until 1999. […]
Hi guys,please
SDRAM 128 MB,PC 100
Voodoo 3 3000 AGP
Thanks 😀
I'll recommend the Intel 440BX AGPSet based boards such as ASUS P2B, AOpen AX6BC, Abit BH6, MSI MS6119, Gigabyte GA-6BXC, EPoX EP-61 BXA-M... many great boards around that era. You can go all the way from PII 233 MHz up to 1 GHz Coppermine Pentium IIIs on many of these boards. I know there are some caveats with Slot1, but if you have a SlotKet adapter, you can use Socket 370 CPUs with these motherboards as well.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 2 of 14, by Allanar
leonardo wrote on 2021-01-05, 23:47:
Hi guys,please
SDRAM 128 MB,PC 100
Voodoo 3 3000 AGP
Thanks 😀
Thank you for the tips,another question please:
How do i know which board supports underclocking to reduce cpu performance for some DOS games...
It doesn't matter that the motherboard was made before than a cpu
Reply 3 of 14, by leonardo
Allanar wrote on 2021-01-06, 08:55:
Thank you for the tips,another question please: How do i know which board supports underclocking to reduce cpu performance for s […]
Hi guys,please
SDRAM 128 MB,PC 100
Voodoo 3 3000 AGP
Thanks 😀
Well... all of them do with multiplier unlocked CPUs. If your CPU is multiplier-locked (like most Slot1 CPUs were) you can under clock by lowering the front side bus speed from 100 to 66 MHz (assuming your CPU is specced for 100 or 133 MHz FSB). However, a more efficient way to reduce performance will be to disable L1 or L2 cache in the BIOS.
For example, if your CPU is the 350 MHz Pentium II (3.5x multiplier, 100 MHz FSB), setting the FSB to 66 MHz will result in a clock speed of 231 MHz. To further handicap the CPU you would turn off L2, L1, or both.
Reply 4 of 14, by PARKE
"Socket 1" refers to [Slot 1 aka SECC] I assume.
There are 4 different 600MHz Slot 1 cpu's and they partially correspond differently with different configurations.
-PIII 600 fsb100 Katmai
-PIII 600B fsb133 Katmai
-PIII 600E fsb100 Coppermine
-PIII 600EB fsb133 Coppermine
It is easier to answer your question when the exact type of your cpu is known.
Reply 5 of 14, by mothergoose729
Coppermine CPUs are not compatible with slot 1 without a slotket adapter. I don't really see the point in getting a pricier slot 1 board if you know for sure you are going to use that particular CPU. A socket 370 board with an ISA slot will work just as well.
A pentium III can be made to run at roughly 386 speeds by disabling L1 cache using setmul, but they can't approximate 486 speeds.
https://www.vogonswiki.com/index.php/List_of_ … sensitive_games
Reply 6 of 14, by Allanar
PARKE wrote on 2021-01-06, 16:48:
"Socket 1" refers to [Slot 1 aka SECC] I assume. There are 4 different 600MHz Slot 1 cpu's and they partially correspond differe […]
yes i meant this III 600E fsb100 Coppermine and the motherboard I want I would take this MSI MS-6163 BX Slot-1
Reply 7 of 14, by PARKE
Allanar wrote on 2021-01-06, 20:45:
Yes, that is a nice and fast board. The 'PRO' version:2 is the best choice.
79.02 KiB
Reply 8 of 14, by Allanar
mothergoose729 wrote on 2021-01-06, 17:36:
I don't know, but according to the compatibility list it should be there
https://www.cpu-upgrade.com/mb-MSI/BX_M ... 6163).html
Reply 9 of 14, by Allanar
PARKE wrote on 2021-01-06, 20:52:
Yes, that is a nice and fast board. The 'PRO' version:2 is the best choice. $_85.JPG
I have the option to buy ver:1 ,for a good price I can use it?
Reply 11 of 14, by H3nrik V!
Yes they are, if board's BIOS and VRM supports them.
Slot-1 Coppermines up to at least 1GHz exist. (Maybe even 1133 MHz, but that's more doubtful if they were released or not).
Reply 12 of 14, by Allanar
H3nrik V! wrote on 2021-01-07, 07:50:
Yes exactly, the BIOS needs to be updated,bois must be used for version motherboard MS-6163 Pro...
Reply 13 of 14, by chinny22
Good news, It's been confirmed V1 boards support Coppermine 😀
Pentium III Coppermine 700MHz - 1 GHz voltage question (MSI MS-6163 Ver 1.0)
Reply 14 of 14, by Allanar
chinny22 wrote on 2021-01-07, 10:29:
great last night i found it 😀
