First post, by Shadow Lord
Hello everyone,
I was hoping maybe someone would recognize either of these motherboards and could direct me toward jumper/switch settings? Sorry but the board will nto allow me to post inline images so you have to click through.
386
The board seems to be working and I have worked out the 4 switch settings for memory size (for the most part...)
486 EISA
If all else fails I can try connecting the board up to a floppy and running the ECU and see what CFG file is missing. Hopefully, then I can match the CFG file to one in mR_Slug's DB.
TIA
