First post, by Shadow Lord
Hello everyone,
I was hoping maybe someone would recognize either of these motherboards and could direct me toward jumper/switch settings? Sorry but the board will nto allow me to post inline images so you have to click through.
386
The board seems to be working and I have worked out the 4 switch settings for memory size (for the most part...)
386 Front
386 Back
386 POST Screen
486 EISA
If all else fails I can try connecting the board up to a floppy and running the ECU and see what CFG file is missing. Hopefully, then I can match the CFG file to one in mR_Slug's DB.
486 EISA Front
486 EISA Back
486 EISA POST Screen
TIA
Reply 3 of 16, by Shadow Lord
luckybob wrote on 2021-01-08, 04:44:
386: https://stason.org/TULARC/pc/motherboards/C/C … -Model-308.html
the 486 I tink was actually made by Intel. but I can't seem to confirm it with my usual sources
I think you are dead on with the 386 - I must have missed it because of the difference in how the ISA slots are setup. However, everything else lines up.
On the 486 board I was thinking an ECS EM486 but I can't find a picture of the ECS board (because of the POST screen). This DFI board is also very close. It could just be differences between Rev 1.0 and 2.0.
Thank you!
Reply 4 of 16, by majestyk
I have this 486 EISA AT board and the ECU demanded a TEKRAM cfg file when I did the configuration.
There is very little information about this board to be found on the net but it´s faster than my (similar) ASUS EISA 486E.
Reply 5 of 16, by Shadow Lord
majestyk wrote on 2021-01-08, 08:20:
Thanks for the info. Do you have the CFG files/OVL/etc. for the board to get it going? Thanks.
Reply 6 of 16, by majestyk
Look for "!TRM0001.CFG" it´s easy to find.
The board identifies as
NAME="EISA-486C SYSTEM BOARD"
MFR="TEKRAM"
The jumpers /switches are not identified 100% correctly though as far as I remember.
Reply 8 of 16, by Shadow Lord
majestyk wrote on 2021-01-08, 08:36:
Look for "!TRM0001.CFG" it´s easy to find. […]
MFR="TEKRAM"
Thanks! With that info I was able to find the cfg file. No OVL file which is weird. All of my other EISA motherboards have an OVL file to help do things the config file can not. Also thanks to your info I was able to find the manual. I did not see the C revision of the MB (only the E) on TH99 is that your experience as well?
Reply 10 of 16, by Shadow Lord
Thanks to everyone for the very quick help! That was fast!
Reply 11 of 16, by Deksor
Shadow Lord wrote on 2021-01-09, 00:02:
Deksor wrote on 2021-01-08, 16:02:
Can you dump your bioses please do I can add them here http://www.win3x.org/uh19/motherboard/show/1150
Unfortunately my programmer isn't working. To be accurate it is a catch 22. I need the 386SX up and running to run the programmer which I can't do if I am copying the ROMs.
You can use this software to dump it from DOS 😀
http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP
Reply 12 of 16, by Shadow Lord
Deksor wrote on 2021-01-09, 10:21:
Cool. I will give it a try once I get the system up and running. Although I have never had any luck with these types of programs. Have you used it yourself?
Reply 13 of 16, by Deksor
Yes. This one is pretty simple. It's the executable equivalent of using the debug command and writing few lines in there. It's copying the first 64kb of the bios, which works perfect for most 286/386 and early 486s.
For newer stuff I'd recommend "uniflash" which I have used quite a lot
Reply 14 of 16, by Robin4
Does this work on 8bit floppy / harddisk controllers as well which have a rom?
Is this program very use to use?
Reply 16 of 16, by Shadow Lord
Well I got the board up and running. Ran the EISA config utility and this is NOT the Tekram board. My first instinct was correct. This is an ECS board. The system is asking for an !ECS1020.CFG file. So anyone have the CFG files for the ECS board? TIA!
