First post, by Mamba
Hello,
I am experiencing a very strange behaviour of the title vga.
It is a 128mb 256bit version of nv40, 350mhz core - 200mhz memory. 8p , 4v.
While testing it on a P2B-D and seeing performance similar or lower than FX3000 (nv35) I decided to play with memory frequencies.
Problem is, they are locked (even if I use driver's tool or rivatuner), setting higher or lower to default...
Any idea why and how to correct?
I can unlock the card to 12p, 6v with rivatuner, maybe flashing a new bios can help?
Reply 1 of 5, by melbar
I think i had the same issue seen with one of my Geforce 6 series cards during a benchmark session.
It's a 6800 LE.
Core clock: 300 Mhz, RAM clock: 350 MHz=700 Mhz effective, 8 / 4 active pixel- and vertex shader.
Your XT has the same core, the clock speed can be different.
Don't remember exactly, but i think i have used two tools: RivaTuner for unlock, and PowerStrip for frequency overclock.
Here my 3d mark results (3DMARK 2001 SE):
6800LE (@300/700): 16291
6800LE (@370/750): 17366
6800LE (@12p/6v/300/700): 17331
6800LE (@12p/6v/350/750): 17522
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 2 of 5, by Mamba
Thanks,
But 3dMark2001se heavily relies on cpu also.
So you should specify which one you have.
Plus, you are telling me that powerstrip unlocked the frequencies?
Reply 3 of 5, by Mamba
Using the suggested Powerstrip method I was able to modify freq values.
But...
Chip cannot go over 350mhz, not a single mhz more.
Memory can be raised of 20mhz, nothing more, and it is strange.
hy5ds283222bfp-33 chips are rated for 300mhz and I am stuck around 200....
Using Nvflash to load a modified bios with some more volt (1.4v) is a no go as it won't access the bios...
This card is a mystery...
Reply 4 of 5, by chrismeyer6
It could be the ram is being supplied a lower voltage with the lower speed. Does the data sheet for the ram list the operating voltage?
Reply 5 of 5, by Mamba
chrismeyer6 wrote on 2021-01-25, 13:14:
Probably,
But as said, nvflash is not able to access the bios modified with Nibitor.
Have you a specific version of nvflash to be used?
