First post, by wide2tele
Could someone please provide simple and very specific instructions on how to remove this CPU fan?
I'm sure I am doing it wrong. Cannot get the silver clamps to lift off.
Reply 1 of 6, by adalbert
After typing number on the lever you can find an image how it looks disassembled, so that may help
    190.99 KiB
Reply 3 of 6, by Doornkaat
It's a stupid mechanism. You need to press down on the large tabs to unhook them and then simultaneously pull the far out side of the large tab up/to the side so you bend the hook away from the retention frame so it does not hook in again when you stop pressing down on the tab.
Reply 4 of 6, by wide2tele
Doornkaat wrote on 2021-01-25, 15:59:
Totally agree with the stupid! Thanks to all, much appreciated, it all helped.
I finally got it off. I don't know who invents this stuff.
It's one of those things that appears near impossible to do until you are told/understand how and you've done it once.
Reply 5 of 6, by bofh.fromhell
wide2tele wrote on 2021-01-25, 16:53:
Totally agree with the stupid! Thanks to all, much appreciated, it all helped. […]
I think its an OEM thing.
Made to mount easily, and who cares about removing or reuse.
Drop it in place, press until you hear the clicks and its mounted correctly.
Reply 6 of 6, by adalbert
bofh.fromhell wrote on 2021-01-25, 17:08:
Look at this server heatsink. I couldn't believe when I first saw it:
670.4 KiB
587.63 KiB
It tells you to discard it after removing. Probably because of used up thermal compound. That's how you care ecology 😀 BTW it works perfectly with slotkets because it's low profile.
