First post, by Albercik
- Newbie
Hello All!
Recently, I've built a PC running a Pentium 166MMX processor on a Powertech MB532 motherboard (AT format). The problem is that there is almost no information on the internet regarding this mobo and I have a serious problem: it seems that my COM ports are not working. The mobo has its own controller with 10-pin headers for COM1 & COM2. I've bought a RS232 ports with a 10-pin connectors (both are DB9) and connected it to mobo.
The problem is that I can't get my mouse to work. It's been tested on another computer and it's working fine, but it's not detectable on my new toy. I've doble-checked my bios settings (not much to set - I just can enable or disable onboard com ports), the drivers in Windows are installed without any any warnings etc. I have no idea if the settings in the device manager are correct, but I've left them default. I've even installed a MS Mouse driver, but its not detecting a mouse during boot (from autoexec.bat).
My PC is running a Windows 98 SE.
Do you know if there could be a different pinouts for COM port header on the motherboard between the manufacturers or is this a standard? Maybe I'm missing something different?
And please - do not advise my to buy a PS/2 mouse as my PC ain't got no PS/2 ports 😉
Thank you in advance,
Tom
P MMX 166MHz, 64 MB, S3 Trio64V2/DX, SB Vibra 16 ISA, 40GB HDD
P III 650MHz, 640 MB, nVidia Riva TNT2, SB 16 ISA, 120GB HDD
486 DX2 66MHz, 16 MB, Trident TVGA8900C, SB Vibra 16 ISA, 2GB CF
