First post, by RedCharles
Got a Zotac 750 Zone today.
335.28 DP works, but there's a two tone/split screen thing going on. Switched DP cables but the two tone/split screen continued. DVI to HDMI works fine.
DP won't work if the monitor is set to DP 1.4. I set it to 1.1. I'm going to try 1.2 shortly. I was hoping I would get more resolutions and hertz choices switching to DP, but I did not.
Installed 34o.52. DP won't display past the Bios/XP loading screen. DVI to HDMI works fine.
I'm using a G9 monitor.
I'm going to try a few more things.
