First post, by RedCharles
Got a Zotac 750 Zone today.
335.28 DP works, but there's a two tone/split screen thing going on. Switched DP cables but the two tone/split screen continued. DVI to HDMI works fine.
DP won't work if the monitor is set to DP 1.4. I set it to 1.1. I'm going to try 1.2 shortly. I was hoping I would get more resolutions and hertz choices switching to DP, but I did not.
Installed 34o.52. DP won't display past the Bios/XP loading screen. DVI to HDMI works fine.
I'm using a G9 monitor.
I'm going to try a few more things.
Reply 1 of 4, by RedCharles
335.04 seems better. Still two tone. DP set to 1.2 opened up 3840x1080 60hz.
In 3840x1080, I don't get the line, but the games are squished.
In 1920x1080 the games have a split.
Reply 2 of 4, by RedCharles
it's not just doing it in game
Reply 3 of 4, by RedCharles
tried different monitor settings. Set it the monitor to 27 inches, and the line went away.
Also got 120hz working at 1080, so the zotac 750 zone accomplished all my goals. Total silence. 120 hz. Super Ultrawide works. Display port connection. Loving it.
Reply 4 of 4, by pentiumspeed
What have to do with monitor's setting at specific size? What counts most is resolutions.
Confused.
Cheers,
Great Northern aka Canada.
